Old 03-23-2007, 02:47 AM   #1
ChinoCharles
Drives: LB
DIY INSTALL/REVIEW: Dezod X-Rated Yaris Brake Pads
MOVED
Old 03-23-2007, 02:50 AM   #2
ChinoCharles
Drives: LB
Old 03-23-2007, 02:53 AM   #3
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
I don't mean to be rude or anything but when you said you don't have to bleed the brakes, you still have to no matter what when you do something like this to your brakes. I've been through two years of auto but i'm still a noob. All we did in that class was dis-assemble American engines *shivers* and re-assemble them and then we moved on to oil changes and brake pad swaps. Still good DIY though
Old 03-23-2007, 02:56 AM   #4
ChinoCharles
Drives: LB
I may have made a mistake. I should mention that. I'm an admitted noob when it comes to anything in the wheel wells. If I did make a mistake tell me and correct me and I'll fix it in the DIY. However, the car performs fine as is and I was in contact with Dezod the entire time, so I don't think there were any mistakes.
Old 03-23-2007, 03:00 AM   #5
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
Haha I'm still a noob also man. Bleeding the brakes is a PITA though. But if you were in contact with Dezod I'm pretty sure they know what they're doing but it might be a nice idea to get those bubbles out of the brake fluid and bleed them though. Still a clean install compared to when I did my first brake replacements.
Old 03-23-2007, 03:25 AM   #6
ChinoCharles
Drives: LB
Oh, and just because I can... work parking lot.
07 Yaris, 03 SVT Focus.
Old 03-23-2007, 07:40 AM   #7
Black Yaris
der Zeck
Black Yaris's Avatar
Oh and for god sakes get some wheels Chino! Nice DIY, and one of your screwdrivers is still in the back of my car.
Old 03-23-2007, 08:22 AM   #8
slothman86
slothman86's Avatar
Drives: 07 Yaris Liftback
Awesome DIY!
Old 03-23-2007, 10:06 AM   #9
OMG you've been screwing in the back of his car??!?!?!?!
But seriosuly, folks, nice writeup, very detailed, anyone should be able to follow these instructions!
Old 03-23-2007, 11:37 AM   #10
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
I have to say NO.
ABS or not, the brakes do not need to get bleed for a brake PAD swap. Especially in this case where is not a 25,000 miles car getting pads.
I would suggest opening the brake fluid cap first though, before compressing the piston back in the caliper.. makes it a bit easier.
Old 03-23-2007, 01:04 PM   #11
Dezod
The Scion Guru
Dezod's Avatar
Drives: Scions
Great DIY Charles. You're such an asset to the community. BTW, I told you would feel a tremendous response difference in braking.
Dezod Motorsports Inc-'We ARE performance."
P: 716-681-6666
E: sales@dezod.com
W: www.dezod.com
Your leading source for all of your performance needs! From turbos and components, to brakes and suspension, Dezod has you covered.
Dezod is offline   Reply With Quote
Old 03-23-2007, 01:06 PM   #12
joey1320
joey1320's Avatar
Drives: Yaris LB
Originally Posted by Chris07LB View Post
I have to say NO.
yeah theres no reason why you would have to bleed the brakes. do open the reservoir and be carefull that when you push back the piston you don't overflow the tank and damage the paint.
so you can place a CLEAN rag on the top of the reservoir to soak up the extra fluid.
Old 03-23-2007, 02:16 PM   #13
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
welp I did say I'm still a noob though =P
Old 03-23-2007, 02:19 PM   #14
ChinoCharles
Drives: LB
I'll edit the DIY with the new info. Thanks for the clarification Chris! Basically, if you do have trouble getting the assembly back on you can remove the bleeder cap and use a C clamp or something comparable to depress the piston. For the record, it was a snug fit but mine went back on without having to do this.
Old 03-23-2007, 02:21 PM   #15
Moose
Resident Redneck
Moose's Avatar
Drives: 07 Polar White Yaris Sedan 5M
When doing a standard brake service (r&r pads & cut rotors) we do not bleed the brakes. It was the same when I worked for Honda and Acura, as well.
I'm sure though, being the 148975616478964564th person to point this out, that it's probably just pissing you off at this point.
My other rides:
2003 Honda Civic LX Coupe 5M- S/C K24 w/ LSD coming soon!
1999 Honda Civic EX Coupe 5M w/ B18 powaa
1985 Toyota Celica GTS Coupe 5M- track whip
http://www.importlounge.com
Moose is offline   Reply With Quote
Old 03-23-2007, 05:09 PM   #16
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
Let's see. If I remember correctly, repeated information gets to people faster than information stated once =P
Old 03-24-2007, 12:27 AM   #17
Dezod
The Scion Guru
Dezod's Avatar
Drives: Scions
Where's the review Charles?
P: 716-681-6666
E: sales@dezod.com
W: www.dezod.com
Old 03-24-2007, 01:36 AM   #18
ChinoCharles
Drives: LB
Well, today I went outside and took all of my clothes off and built a bonfire. I began chanting in something that sounded to be of a West African origin, but nobody could really tell. After about an hour I realized I cannot drive rain clouds away by speaking to trees and went back inside.
58 and partly cloudy this Sunday.
Big Brake kits for Yaris 5 door mojoyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 03-23-2007 01:30 AM
