08-12-2014, 01:11 PM | #1 |
Drives: 2007 Yaris Join Date: Aug 2014
cobalt rims will they fit on a 2007 yaris
just picked some chrome 16x6 rims that were going to go on a cobalt, same 4-100 bolt pattern but just curious if anyone might know of other possible fitment issues between the 2 cars when it comes to rims. I'd hate to buy new tires just to find out they need spacers due to sometime i only realize when i drive down the street with them the first time
thanks ahead of time |
08-12-2014, 02:09 PM | #2 |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
I believe stock offset for cobalts is +42, so they should fit fine on the Yaris.
08-12-2014, 02:38 PM | #3 |
You may need hub rings cos our hub bore is 54.1 in order to keep the wheels center and no wheel vibration.
08-12-2014, 03:01 PM | #4 | |
Drives: 07 Yaris Sedan Aero Join Date: Oct 2006
Preferable but not necessary. These hub rings are not easy to find. The lugs will Center the wheels perfectly. |
08-12-2014, 03:02 PM | #5 |
thank for the info anywhere online youd recommend grabbing hub rings or is that something every tire shop should have?
08-12-2014, 03:03 PM | #6 |
08-12-2014, 03:10 PM | #7 |
No they will not on a four bolt wheel u need rings on a five bolt yes ...good luck with four
sent from my S4 on Mars |
08-12-2014, 03:11 PM | #8 |
Any whhel shop should have them in stock
08-12-2014, 03:19 PM | #9 |
Cobolt is 57.1 so u need 54.1 to 57.1 rings
http://www.amazon.com/gp/aw/d/B00DIK...&robot_redir=1 sent from my S4 on Mars Last edited by Exiwolfman; 08-12-2014 at 03:32 PM. |
08-12-2014, 04:05 PM | #10 |
Drives: 06 Polar White 5dr, 13 Soul 4u Join Date: Oct 2008
^ I'd try to find plastic ones tho, as you'll have no issues with ring fusing to the wheel. I've had problems with aluminum but never with plastic.
08-12-2014, 04:18 PM | #11 |
08-12-2014, 05:09 PM | #12 |
Drives: 3-door hatch Join Date: Oct 2010
Four or five, the lugs will center the wheel. I have 4X100 Volk TE37 on my Miata (a car that is notoriously sensitive to wheel defects) and although they came with very nicely made aluminum rings, when the lugs are torqued up, the rings just float around loose inside the bore. Took them out because of corrosion issues and never had a problem with the wheels.
08-12-2014, 05:15 PM | #13 | |
08-13-2014, 05:16 PM | #14 |
"99%"? LOL.
I have never heard of anyone having problems with non-hub centric wheels. While going to college, I worked at a high-end Japanese wheel importing company. Never had/heard of issues with non-hub centric wheels. Most of their products were non-hub centric. It makes sense on German cars because for some reason they like (liked?) to use lug bolts instead of studs/nuts. So the hub centricity made it easier to install wheels. Otherwise you can just hang the wheels on the studs. You think I am "cheaping out"; I think you're wasting money. |
08-13-2014, 05:38 PM | #15 |
Well i can say one thing wheels come with proper hub bore for the car from factory , generic hub bore on after market is 73 so if u say that is fine on a 54 bore hub with 4 bolt pattern ...well all the luck with that and if u have worked at a place like that then u would recommend rings , yes five bolt up works on four not so well but do what u like and don't complain when u have vibration at high speeds honestly u are being cheap do it right or don't bother at stay with stock wheels lol
11-03-2021, 08:40 PM | #16 |
Drives: 03 Toyota Echo Join Date: Nov 2021
I have Mazda3 aluminum mags on the Echo.
02-03-2022, 08:59 PM | #17 |
Drives: 2007 Toyota Yaris Sedan Join Date: Feb 2019
How can anyone with mechanical experience think that a plastic piece can be used to support a wheel that hits potholes. LOL. Either you're gonna be in the camp of hubcentric is necessary even though the lugs are coned, and you'll use metal rings, or you won't use any rings at all because if the wheel relied on plastic to stay centered that sh1t would self destruct first pot hole you hit
02-05-2022, 01:18 PM | #18 | |
Drives: 2007 5dr canadian import Join Date: Dec 2016
now if we were talking about heavy trucks, then yes, the center bore is actualy load bearing to some extent but again it doesnt truely come into play unless things are loose at which point your in for a disaster anyway i should mention the other exception..and that is badly manufactured wheels, will often need them as the nuts dont lock the wheel down very well, working in the tire/wheel industry i only came across this a few times something to keep in mind is that most cars prior to the 80s were 100% lug centric only, no hub contact to keep anything in place, often times the center of the wheel wasnt even round, if a car uses accorn nuts and the wheel accepts them the hub in the center is typically trivial, unless the studs are too weak to support the load...which is rarely the case |
Similar Threads | ||||
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
Consumer Reports Is On Crack!!! | doublewam | General Yaris / Vitz Discussion | 82 | 05-07-2011 11:03 AM |
Set of 4 2007 Yaris Steel Rims and Hubcaps | mattyboy | Items for Sale by private party | 0 | 09-13-2010 09:25 AM |
2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 04:54 PM |
