Old 01-25-2015, 05:04 PM   #1
Eduardo_mty
Additional roof led light
I bought this led light to install as additional roof light
How i will tap to works like oem.
I mean if i open the door, lights turn on
The red wire from light panel, if i conected to to blue wire on switch its allways on.
If i tap the red wire on white/Black strip, no turn on
Eduardo_mty is offline   Reply With Quote
Old 01-25-2015, 05:15 PM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
You need to test out what the wires on your LEDs do.
You have three wires: blue, red and black. I assume black is ground.
When the red wire is connected to a power source, what happens to the LED?
When the blue wire is connected to a power source, what happens to the LED?
You'll also have to test the wires on the plug with a test light or probe.
Also test when the dome light is in the ON, as well as the DOOR position.
From there, you can determine how to hook up your LED.
Old 01-25-2015, 05:21 PM   #3
Eduardo_mty
Black and red from panel to Black and blue from switch.. Turn on.
Black and blue from panel to Black and blue.. Nothing
Black and blue from panel to Black and white Black strip... Nothing
Old 01-25-2015, 05:29 PM   #4
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
That's not what I meant.
You need to use a test light and/or probe and tap into your plug to find out what wires are hot and what ones are ground.
Then on your LED, test the wires to see what happens to the LED when connected to the red or blue wires. If your LEDs came with an information sheet, that would help as well.
Old 01-25-2015, 05:29 PM   #5
Eduardo_mty
With door closed.
White wire on switch, no light in test light.
Blue wire turn on, in test light.
Black wire turn on, in test light
Open door.
Black wire no light in test light
Old 01-25-2015, 05:45 PM   #6
Eduardo_mty
Please check it
With door closed
Old 01-25-2015, 06:22 PM   #7
Eduardo_mty
Electrical Circuit..i
Old 10-06-2018, 11:59 PM   #8
eeeeeh
Drives: Yaris YR 2013
@Eduardo_mty, did you manage to get this working? I've got a MkIII Yaris in Australia and trying to do something similar to what you're doing, by tapping the front map light assembly, but not having much luck...
eeeeeh is offline   Reply With Quote
AZ People jmew0ng Southwest 63 05-12-2024 11:47 AM
official JOLT YELLOW Yaris thread! firebird1999us Photo-Video-Media Gallery 68 08-01-2019 05:35 AM
Upper third brake light led mod for the yaris sedan YarisSedan DIY / Maintenance / Service 2 05-22-2013 12:52 AM
Best looking/fitting LED tail light replacement Yarflana DIY / Maintenance / Service 2 02-26-2013 10:51 PM
