Old 02-07-2015, 11:38 AM   #1
scod4025
Drives: 12 LE 5d HB 1nz-fe Automatic
It has Begun,Ok so now about half way
Hello to all
Well After much research (manly from this Forum) have begun to modify my 2012 Yaris LE HB
The first Install so far was the aFe intake and the Micro Image Intake Manifold
Had a slight issue with MAF not fitting the aFe intake but little bit of sand paper and that was fixed. So far only have about 5 days of to and from work on it but there is a noticeable increase in power at lower rpms, Have a crap-o-matic so don't know in what range but still loving it.
Thanks to Jeff at Micro Image for help that was provided and listening to my dumb questions and I will be calling back when bonus shows up next week for the Tanabe Cat back and headers
Now if only there was Semi-Automatic tranny that would fit this thing
Yes I would convert to a manual if was able to but needs to stay as automatic for DMV purposes for now
On this note I have been looking and it seems only one person has done the TB change over with a Third Gen Yaris and had some issues was wondering if any one else had done this as well and did or didn't have issues looking for one now but trying to figure out what to look for as to problems
scod4025 is offline   Reply With Quote
Old 02-07-2015, 11:41 PM   #2
WorkTL
WorkTL's Avatar
Drives: 2013 Yaris LE
Any pics?
WorkTL is offline   Reply With Quote
Old 02-10-2015, 07:52 AM   #3
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
Track car, Yay! :D
Old 02-10-2015, 04:30 PM   #4
scod4025
ok so only have after pictures had thought that it was a pretty easy install so didn't do any pictures
but here they are
Here is one of the things that bothers me so will need to do some modifying to my cover but works for now
The air manifold came with spacers to lift the cover up so wouldn't rub on the manifold but don't like the way it looks so going to pull my dremal out but that can wait
and Just noticed this
Hose is touching will see if can twist that hmmm... anyways
Hope you like and next few Install's will get pictures taken while doing the install
Old 02-11-2015, 10:01 AM   #5
scod4025
ok so added some after pictures but need to get approval or something the redirect was to fast for me to see what issue was
Old 02-11-2015, 10:53 AM   #6
scod4025
AH HA I win got one picture to upload will do more later
Old 02-12-2015, 11:41 AM   #7
scod4025
Ok have the TB to install so my weekend is set[IMG][/IMG]
Old 02-18-2015, 10:49 AM   #8
ColdToiletSeat
Drives: 2001 Toyota Echo Red Sedan
is this the 1NZ-FE engine?
EDIT: Sorry, I should have read what you drive xD
ColdToiletSeat is offline   Reply With Quote
Old 02-19-2015, 11:07 AM   #9
scod4025
Ok so not sure if should put here or in exhaust thread but going to drop here
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Shiny
Old 02-19-2015, 11:46 AM   #10
scod4025
I had a shop do the work, I wasn't going to do it that way but it was on the rack and he gave me a really good price for the work.
So it is now all 2" from the resonator back My new exhaust guy had to cut the connection off the Tanabe muffler because it had 1"3/4 pipe to connect to my old pipe which became 2"
I will be installing DC headers this weekend
Old 02-19-2015, 04:18 PM   #11
axiom
axiom's Avatar
Drives: 2007 Yaris
I really want to do the MI Intake Manifold, but have not bit the bullet, the price seems so high. I have the 1ZZ TB so really should be doing this.
axiom is offline   Reply With Quote
Old 02-19-2015, 04:26 PM   #12
scod4025
It is worth it. I have lost a little in my MPG but lots of low end umph
Edit: Should state that the loss of MPG may or may not be from the fact that my foot seems to have gotten a bit heaver. I don't speed per say, just like to get up to speed faster then everyone else around me
Old 02-19-2015, 08:05 PM   #13
WorkTL
WorkTL's Avatar
Did the car run fine after the manifold install. I might buy this next, will this give you any problems at the smog place?
Old 02-20-2015, 10:44 AM   #14
scod4025
Had no problems with the intake manifold after install. um don't know about smog but I keep all of my factory pieces just incase it's a real easy install like 45mins and I'm back to stock
Old 02-20-2015, 02:50 PM   #15
axiom
axiom's Avatar
Drives: 2007 Yaris
Damn it, look what you made me do. I ended up ordering the MI Intake Manifold.
Old 02-20-2015, 05:34 PM   #16
scod4025
Old 02-25-2015, 09:50 AM   #17
scod4025
Need a little input from you guys
Ok so started looking into my next mod, Light weight pulleys, fly wheel etc...
and came across some disturbing post so was wondering if there is still issues with the pulleys and such or where these few and far between. Or do you guys think there is a Different Mod I should be looking into
Also have the question of should I Go with a 10% undersize or stick with OEM size.
Trying to scrape out every little bit of HP with out adding F/I (YET)
Old 03-01-2015, 10:07 AM   #18
WorkTL
WorkTL's Avatar
I would just go with the MicroImage pulley. I noticed the car revs quicker and don't have to worry about it cracking.
Blitz install has begun!! wildmongoose26 Forced Induction Forum 6 03-20-2013 09:41 PM
yaris mods have begun... matrixmanvvtl_i Cosmetic Modifications (Exterior/Interior) 12 10-01-2007 03:26 PM
