03-26-2015, 07:05 PM | #1 |
Drives: yaris Join Date: Mar 2015
No power to engine fan
Recently replaced the water pump and alternator on my gf's 2009 yaris and while i was burping the system i noticed the fan never came on so i turned on the a/c because i knew it would turn the fan on....nothing... so i began checking the fuses all were good so i decided id throw a new relay in fan no. 2 power is coming into the relay but still no power being sent to the fan....fan still works i jumped power to it and it spins and its a new fan but test light shows no power coming into the plug...any help would be greatly appreciated because i'm about to set this thing on fire lol
03-26-2015, 07:14 PM | #2 |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
The fuses involved are 30A RDI and 10A ECU-IG
Fan No.1 Relay is part of the integration relay (the chunk where the RDI fuse is mounted to). To see if he is bad, pull that chunk up by releasing the clips on either end. Once you do, look at the center connector on the bottom of him. Pin 5 is blue: +12 V via RDI fuse Pin 6 is black: +12 V from the ECU-IG fuse (with the ignition switch in the on position) Pin 7 is orange: 0V when the ECM decides the fan should be on Pin 8 is light blue: +12V output to the fan (when the fan should be running)
03-26-2015, 07:33 PM | #3 |
CTScott turns out its was a bad fan no.1 relay thanks for curing my head ache!! lol now i can fix it
Similar Threads | ||||
tooter's manifold adventure... | tooter | Performance Modifications | 1465 | 07-31-2014 09:11 PM |
DIY adding extra power outlets and usb power outlets on the dash to use phone as GPS | julienrl | DIY / Maintenance / Service | 1 | 08-31-2009 11:06 AM |
The last gas question | Tonavi | DIY / Maintenance / Service | 56 | 04-27-2009 09:40 PM |
Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 11:07 PM |
