Old 05-02-2007, 05:08 AM   #1
Yaris T-Sport
Nov 2006
Drives: Vitz S1600
Yaris T-Sport is offline   Reply With Quote
Old 05-02-2007, 05:58 AM   #2
Yes I do have a breather tank, but the guys at the workshop took care of the instalation, they used an e'spec brand T-joint, I'll go take a closer look under the hood if it mentions anything about size...
Old 05-02-2007, 06:15 AM   #3
dammit, didn;t take a picture, but it looks very much like the one you posted. And it has a big 30MM on the side, I think that's a hint
Old 05-02-2007, 11:20 AM   #4
joey1320
joey1320's Avatar
Drives: Yaris LB
so how is this any different than the reservoir??? sorry for the stupid question i just don't see the benefit of it.
Old 05-02-2007, 08:13 PM   #5
The function of these is basically to collect bubbles that may form in the cooling liquid, to prevent them from recirculating, which improves cooling efficiency. Probably most effective under heavy loads or long drives.
Old 05-02-2007, 10:16 PM   #6
joey1320
joey1320's Avatar
Drives: Yaris LB
humm ok. how are bubbles gonna form in a closed system? the only way is incorect bleeding... only the coolant starts to boil which will be almost impossible in a good runing system.
Old 05-03-2007, 01:09 AM   #7
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Thats pretty much useless. Bubbles dont form in a closed system as stated above. Also if its hooked up as shown in your diagram, water will bypass the radiator.
Old 05-03-2007, 01:17 AM   #8
largeorangefont
Break'em off some.
Originally Posted by Yaris T-Sport View Post
YEEEEESSSSSSS!!!! it's useless..
Indeed!
On top of it being useless you are going to drain the coolant back into the lower radiator hose through a guage sensor port?
Old 05-03-2007, 08:00 AM   #9
joey1320
joey1320's Avatar
Drives: Yaris LB
well said, well said,
sorry dude i was not trying to put your kit down, i was just trying to figure out why would anyone need thise? besides the fact that it looks cool
hey is your money man, you do what you want with it!
Old 05-03-2007, 08:40 AM   #10
it's.... it's.... it's japanese so it must be good!
But is the engine cooling system really always a completely air-free, perfectly closed loop?
Old 05-03-2007, 09:05 PM   #11
largeorangefont
Break'em off some.
If you had an air bubble your car would overheat.
Old 05-04-2007, 06:44 PM   #12
joey1320
joey1320's Avatar
Drives: Yaris LB
well it will make the needle(or light) go to hot/on since the steam is hotter than the coolant, and then it will drop once it passes. still not good for your car. but that would only form from a leak or bad bleeding.
Old 05-04-2007, 10:20 PM   #13
heylookitsjames
maintenance of momentum
Drives: 2007 5spd 3dr
Brings back horrible memories of my aw11... what a biatch to get all the air bubbles out. We should all be thankful that the rad is on the same side of the car as the motor in the yaris.
heylookitsjames is offline   Reply With Quote
Old 05-05-2007, 02:08 AM   #14
largeorangefont
Break'em off some.
Depends on how big the air bubble was. If it is big enough, Water won't flow at all.
Old 05-06-2007, 12:53 AM   #15
largeorangefont
Break'em off some.
thats what the breather tank for, is to reduce as much bubbles as possible in the cooling system to provide max cooling.
There are no bubbles to be reduced. If you have bubbles the system is not full or properly bled. All that thing does is let coolant bypass the radiator to provide less then max cooling.
Old 05-06-2007, 06:56 PM   #16
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
More great info from LargeOrange.
Looking to add Cruise to my 2007 Liftback yaris Yaris_420 Performance Modifications 3 01-28-2007 06:46 AM
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 08:45 PM
