Old 11-23-2015, 10:07 PM   #1
07HBYaris
07HBYaris's Avatar
Drives: Yaris HB 2007
Hi and Low Beam at the same time trick
I have figured out this neat little trick with the Yaris years ago. It makes a world of difference at night. I also adjust my left and right head lights just a tad.
It's about time I shared this.
Note: It takes some dexterity to get it right.
All you have to do is move the lever inbetween the hi and low beams. If you get it just right it'll stay.
I noticed the more I did this the more it stayed. In the beginning, the lever would get knocked back to low beam with just a small bump in the road. But after doing this for years, my lever now has technically 4 options. I say, mines sturdy enough to stay in place for indefinitely on typical roads.
toggle hi beam
hi & low combo beam
lo beam
hold hi beam
I have done this since the day I figured out this trick back in 2008-9, and now you can have both filaments on. I Never had any had premature lights wear. no popped bulbs or melted housing. No negative consequences.
I only used plain old halogen one. Not the cheapest, not the fanciest, just the most OEM looking ones.http://www.yarisworld.com/forums/ima...s/thumbsup.gif
no a/c + traffic =
07HBYaris is offline   Reply With Quote
Old 11-23-2015, 10:17 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
ya till you blow ur relay or melt something
Old 11-25-2015, 12:32 PM   #3
MadMax
MadMax's Avatar
^^ Yep! ^^
Old 11-25-2015, 01:07 PM   #4
I'm assuming you drive on a lot of rural roads and need the extra lighting? Other than that I can't image why one would need more than a simple high beam...definitely not on day to day well traveled roads.
Old 12-30-2015, 09:19 AM   #5
Squid111999
Squid111999's Avatar
Drives: 08 Yaris hatch
Came across this months ago and game it a shot. Its a fun little trick to show off and I feel is pretty handy on windy roads. Thanks for the tip
Sent from my XT1254 using Tapatalk
Squid111999 is offline   Reply With Quote
combo, high, lights, low
