Old 11-24-2015, 11:02 PM   #1
SirDigby
Drives: 2007 yaris 3 door
Build your own throttle body spacer!
hello. i'm in the process of porting a manifold and installing a 1zz throttle body. I do not like the placement of the throttle body and air flow direction so I want to add a throttle body spacer. after doing some searching I can't seem to find anything that I like so i'm making my own.
the main issue I have is that ALL the spacers I find are made from aluminum. that's ok, but aluminum can hold/transfer heat and can be pours if cast poorly. plus they are all in the $80 range.
i'm making mine from a phenolic sheet in L grade. it's a "slab" made from fibers and resign that is pressed and heated to create a very good, heat resistant material. the L is for linen, which is the fiber in this block. it only comes in 12x12 sheets, so I will be using <1/4 of it. if anyone wants a piece, I will send it to you for $12 plus shipping. (it has a thickness of 1/2")
i'm going to cut groves for o rings on both sides and use it as a spacer/o ring block. I will post pictures next week....
Old 11-24-2015, 11:29 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Sounds like a cool project. I use a Delrin gasket to deal with heat transfer with my manifolds.
Sent from my XT1575 using Tapatalk
Old 11-25-2015, 12:15 AM   #3
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
Really cool project!! Looking forward to seeing the result.
For reference, here's a CAD drawing of the engine intake ports Crankyoldman made during the design phase of the "tooter" manifold. It might prove usefull.
http://www.yarisworld.com/forums/sho...24&postcount=7
Old 11-25-2015, 07:39 AM   #4
Hmm, i'm definitely interested in this. i'm curious if a 1/2" would make any noticeable difference in torque. I'd probably just use some RTV so make a seal as opposed to an o ring. Since I ported my intake manifold to match it with my 1zz TB I got rid of the o ring and just used RTV. If you take the time to let it semi harden then it seals itself really well.
Are you porting your manifold using the JB Weld method? If you are you'll love the results, personally it's been one of the best mods to date.
I have a buddy that works for a design company and deals with auto CAD. I'm going to send him the design that Cranky came up with and see if he has the ability to make it or not. I love the simplicity of Tooter's spacer and if I can do it relatively cheap then it's a go.
Old 11-25-2015, 09:16 AM   #5
That's an intake manifold spacer. OP is fabricating a throttle body spacer.
Old 11-25-2015, 10:06 AM   #6
does anyone have the full CAD tooter had posted for the manifold spacer? The link posted above is missing dimensions
Old 11-25-2015, 12:30 PM   #7
Dimensions are all on it.
Old 11-25-2015, 01:04 PM   #8
I sent it to my buddy who deals with the stuff for his job and he said that it missing some dimensions for the gasket groove. He said he could estimate it but in the end it would cost way too much anyways to be worth while.
I was hoping he could do it in a cost effective way, guess I'll have to wait until someone is eventually selling theirs...
Old 11-25-2015, 01:16 PM   #9
Ah yes.
Old 11-25-2015, 06:33 PM   #10
SirDigby
I have the manifold here... it's 5mm deep and 4.25mm across for the gasket-to-head.
and yea, i'm building a tb spacer, but I might build one for the runners.... humm...
Old 11-25-2015, 06:36 PM   #11
SirDigby
oh, I did seal up all the gaps and cut out the stock o ring land. I added jb to the outside too so I can clean up that corner on the right. i'll be cleaning it up this weekend. i'll take pictures and post them when i'm done.
Old 11-25-2015, 08:45 PM   #12
If you make one for the runners let me know, i'll take one!
Old 11-26-2015, 02:56 AM   #13
invader166
Pumpman
Omg!! I definitly read the OP's post all wrong!! Thought you were talking about an intake manifold spacer. lol
You're in luck though!! I actually have an aluminum 1ZZ throttle body spacer on hand that I plan on using for one of my projects.
I can probably make a drawing with some dimentions if you want.
Old 11-27-2015, 12:45 PM   #14
Fluxtasy
feed my pet
Fluxtasy's Avatar
Drives: Yaris Sedan '10
I don't have the tools nor the skill to do a port matching on the intake for my 1ZZ TB so I decided to purchase a TB spacer from the seller below:
http://www.ebay.com/itm/KC-TBS-Toyot...9SOIQk&vxp=mtr
Fluxtasy is offline   Reply With Quote
Old 11-29-2015, 06:40 PM   #15
SirDigby
the spacer is 80mm x 80mm the flow opening is 57mm screws are....8mm? idk what the o rings are for depth as I need to purchase them tomorrow, but they will be 65-70mm, depending on what I can find. (prob something like 1 3/4")
o ring depth probably be around 1-2mm
Old 11-29-2015, 09:16 PM   #16
Will this have the same positive effect on low end torque like the manifold spacer has (assuming both spacers are of the same thickness)?
Old 12-18-2015, 11:06 PM   #17
SirDigby
it just keeps flow up through the TB into the manifold and adds a few more cc's of available air in the manifold. if you added a spacer to the intake runners you are lengthing the intake runner and increasing the straight line velocity at the front of the head port. you would also increase the available cc's. they would not have to be the same thickness if you used both.
I hope to have it finished tomorrow so I can post pictures...
Old 12-23-2015, 08:22 PM   #18
SirDigby
I have finally finished.twas' a pain in the ass. it's probably just best to buy one.
this is where it'll go...duh
I didn't think about the o ring, and it would be difficult to do without the proper tools. I had a tool made to cut the o ring, but it could be done with a hole saw if you were careful. cut it first, then cut the bore.
it wasn't too bad I guess...
intake, spacer, throttle body
Carbon build up in the throttle body Sedan DIY / Maintenance / Service 18 11-15-2013 11:44 PM
Throttle Body spacer? jekqmb Performance Modifications 2 10-04-2011 11:02 PM
FS- 1ZZ Throttle Body, Spacer, NST SSK MGargano Items for Sale by private party 9 09-01-2010 08:48 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
