Old 05-17-2016, 01:02 PM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Blitz S/C: new failure mode!
So I've been abusing my Blitz for around 3 years now, and it's given as many punches as it's taken. I've lost 2 aluminum crank pulleys in the last 12-15 months, 2 or 3 belts, and have a bad oil seal somewhere that results in my accessory belt area being coated in a light dusting of engine oil and rubber dust. Very dirty stuff to work with.
So the latest failure mode was the main bolt that goes through the OEM alternator mount shearing off between the mount and the Blitz bracket. The bolts are all-thread--which is less than ideal from a wear standpoint--but if I was that worried about it I could replace them with the right bolts.
It's been working itself free every few months for the last year or so, and I just tightened it back up with whatever torque I could manage using a ratcheting box wrench. You can't get in there with a socket, and if you knock the protective cap off the alternator cable, you will blow your main fusible link. Don't ask how I know that...
There's been a bit of noise up there as well, but I assumed that the looseness was the cause of the squealing/chirping, or that the tensioner pulley had a bad bearing. Or both. Turns out that the alternator was gummed up from the oil/rubber dust and wouldn't turn freely.
The bolt at the top of the bracket had stripped out after about a year, and I haven't gotten around to removing the motor mount to get enough clearance to run a larger tap. I also didn't realize that there are two bolts that can go through the bracket into the end of the "neck" of the pulley. I got one of them to thread in, but for some reason neither of my kits had the right bolts to put in there in the first place.
I'm sure that the tension I put on the belt is a significant factor, but even when it's slipping at 5k, it's still breaking other things.
Pics:
Old 05-17-2016, 04:50 PM   #2
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
Wow. That sucks, Cranky. I hear so many bad things about these units. It's a shame really.
brushforhire is offline   Reply With Quote
Old 05-17-2016, 06:02 PM   #3
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
What in the world do you do to your car? lol
My Blitz has been on for about 40k miles so far. I haven't had any problems out of it.
Old 05-17-2016, 10:30 PM   #4
CrankyOldMan
Drive it like I stole it, every day. AutoX on the weekends for extra punishment.
Old 05-17-2016, 10:39 PM   #5
CrankyOldMan
They're not intrinsically bad, I just don't baby it and don't fix it before it breaks.
Old 02-26-2017, 02:56 PM   #6
AzianCuz
conundrum562
AzianCuz's Avatar
Drives: Toyota Yaris 2007 Type S
Send a message via AIM to AzianCuz
Shit.... Mine is making some noises and I lubed it with WD40 seems to be running smoother now, but I think I have the exact same problem... HELP.... What should I do??? Before lubing that part the S/C was really laggy...
BLITZ S/C|MICRO-IMAGE CRANK PULLEY|NST ALT;WATER PUMP PULLEY|BLITZ SUS SHORT RAM;HEADERS;AXLE-BACK EXHAUST|2.25 PIPING|1ZZ INJECTORS|OPTIMA YELLOW-TOP|GTSPEC FRONT STRUT;MID LOWER CHASSIS;4 PNT FRNT LOWER BRACE|WHITELINE REAR SWAY;BUSHINGS|TANABE FRNT SWAY|TRD LOWERING SPRINGS/SHOCKS|R1 CONCEPT DRILLED & SLOTTED ROTORS|EBC GREEN PADS|THROTTLE SPACER|XTREME PERFORMANCE CHIP MOD
AzianCuz is offline   Reply With Quote
Old 02-26-2017, 03:49 PM   #7
Geeze, that's why I optend for the 2zr...Yota reliability and less having to deal with parts contunuing to fail. Boosting an engine never meant for boost is always a constant project from what I've read. It also doesn't help that with Toyota's ECU's you can't just re write the engine tune, you have to run a darn piggy back.
tmontague is online now   Reply With Quote
Old 02-26-2017, 08:05 PM   #8
CrankyOldMan
I think we have it sorted out. It's the idler pulley, which is just a double-sealed unit. Off the shelf replacement with a 6301 series. Well, at least we hope that's the fix. If not, the other bearings all require a non-trivial tear down to replace.
Old 03-10-2017, 11:53 PM   #9
AzianCuz
conundrum562
AzianCuz's Avatar
Anyone had this problem? Listen to that sound, is it the tensioner bearing?
See link below:
View My Video
Blitz S/C + Cruise Control? 47_MasoN_47 Performance Modifications 37 03-03-2013 07:28 PM
Blitz S/C a rebuilt and rebaged Toyota S/C? Yaris0609 Forced Induction Forum 3 03-13-2010 12:21 AM
old article about blitz s/c but interesting info.. AdeJong 03 Forced Induction Forum 4 09-18-2009 02:08 PM
fixed my blitz s/c problem for now laszlo Forced Induction Forum 3 04-19-2009 10:24 PM
Blitz S/C on 08 Yaris whooppee777 Forced Induction Forum 12 11-26-2008 01:45 PM
