Old 05-21-2016, 05:01 AM   #1
rabbito
rabbito's Avatar
Polishing Throttle Body
T.B polishing is really popular here, $50 for full polishing inside the T.B..i do not know about the hp gain but i want to know if anyone tried this 😃😃😃😃
Sent from my SM-J700F using Tapatalk
Cosmetic: Toyota red emblem
Old 05-21-2016, 11:27 AM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
There would be no power gains really. The only possible benefit that I could fathom is maybe slightly quicker butterfly actuation.
Sent from m-o-b-i-l-e
Old 05-22-2016, 06:54 PM   #3
NJP440
2010EGGHATCH
NJP440's Avatar
Drives: White 2010 Yaris Hatch
I just picked up a 1zz throttle body for my Yaris. That's the only real throttle body gain I've heard of for these cars so far.
Sent from my SM-G920T using Tapatalk
IG: 2010EGGHATCH
NJP440 is offline   Reply With Quote
Old 05-22-2016, 09:03 PM   #4
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
From what I was reading up on, there can be some benefits to polishing the throttlebody, but usually when porting it a bit also. It had to do with removing any imperfections and opening the entrance a bit. Mostly trying to just remove the step as the air enters the TB.
That being said, even doing that on a factory setup probably won't net any benefit, with an intake and exhaust possibly, with an all out build I would imagine that it would help squeeze any hidden potential out of it.
Project so far: 2zrfe swap, Megan racing coilovers, TRD rear sway bar, whiteline bushings, RPM long tube header, midpipe, and DC sports xD exhaust, brake upgrade in front, MI stainless braided lines all around, matte paintjob, Takada cold air intake, various gauges, rear seat and belts removed.
Future: Turbo.
brushforhire is offline   Reply With Quote
Old 05-22-2016, 11:31 PM   #5
rabbito
rabbito's Avatar
yeah but 1zz TB must use intake kit...theres like no point if you dont use intake...im not trying to use intake kit(which i did before and lost low end)...
Old 05-23-2016, 07:34 AM   #6
Rigaud
Drives: 2009 Yaris
Then you did something wrong because low end is greatly improved with the 1ZZ TB.
2009 Toyota Yaris (Little toy)
2002 Audi A4 Avant Quattro 3.0L (Big boy toy)
1998 Subaru Legacy GT 2.5 (winter & DD)
Rigaud is offline   Reply With Quote
Old 05-23-2016, 07:35 AM   #7
rabbito
rabbito's Avatar
im talking about having intake kit..not having 1zz tb..
Old 05-23-2016, 09:38 AM   #8
Anchors15
Drives: '15 Yaris 3 door
Does anyone know is a 1ZZ swap will work for a 3rd gen Yaris? (2015 3 door)
Anchors15 is offline   Reply With Quote
Old 05-30-2016, 02:07 PM   #9
SirDigby
Drives: 2007 yaris 3 door
if you swap the chip you should have no issues!
Polishing 1NZ Throttle Body rabbito Performance Modifications 3 02-25-2016 11:36 AM
Throttle Body Swap Ryze268 Performance Modifications 12 04-27-2014 01:46 PM
Cleaning throttle body ToTo Performance Modifications 18 07-27-2011 05:20 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
