Old 10-04-2016, 08:46 PM   #1
Dodge Aries K
My Yaris is a "racecar"
Drives: 2007 Yaris hatchback
Carpet pulls out of the sides in rear seat area
Anybody else have an issue where the carpet pulls out from under the B pillar trim and the rear sill panels from people getting in an out of the car? It's almost like the carpet is too short so it doesn't stay underneath the panels when it gets pushed down a bit.
-Karl the Uber/Lyft Driver
Dodge Aries K is offline   Reply With Quote
Old 10-04-2016, 11:48 PM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
Yes, I have the same problem. The carpet barely fits under the plastic door sill and easily pulls out if you don't keep your feet in the middle of the floor and away from the edge close to the sill. I guess Toyota could have been a little more generous with the width of the carpet.
Old 10-05-2016, 10:41 AM   #3
Dodge Aries K
Jeez. What year is your car? Mine in question is a French built 2014 Yaris LE. My 2008 Yaris sedan doesn't do this sort of thing...
Old 10-05-2016, 10:44 AM   #4
2014 French built, same as yours.
Old 10-05-2016, 11:03 AM   #5
kimona
kimona's Avatar
Yes, a French built 2014. I like my 2014; however, the quality doesn't approach that of my 2007.
Old 10-05-2016, 01:35 PM   #6
texascolt45
Drives: 2015 yaris
i'm seeing a number of little things on my French built 2015.the interior quality is cheap.still wouldn't trade it for a honda though.
texascolt45 is offline   Reply With Quote
Old 10-05-2016, 01:48 PM   #7
Dodge Aries K
Does your 2015 do the same thing?
Old 10-06-2016, 03:19 AM   #8
mrpj
Drives: 2014 Icon+ 1.33l Multidrive
My French 2014 doesn't have this problem.
Could you use some spray on adhesive to stick the carpet in place after first removing the sill trims?
If it doesn't work, and you ensure all the doors are shut when you do it, I can guarantee you'll leave the car laughing and singing for a while!
mrpj is offline   Reply With Quote
Old 10-12-2016, 10:30 PM   #9
YarTed
Drives: 2015 Yaris 5Dr
I have Canadian 2015 LE, I was vacuuming the car and remembered this post. All my rear carpet is where it belongs, looks good. I need to qualify that back seat seldom gets used. I can see that the interior probably would not look to good if it was abused. Mine is pretty mint and will likely stay that way and I really like the seats. At any rate, am at 41,000 KM's and am really enjoying it.Cheers
YarTed is offline   Reply With Quote
Old 10-12-2016, 10:56 PM   #10
Dodge Aries K
If you push down hard in the corners of the rear carpeting, it will cause it to pop out if there's an issue. I just looked at a used 2015 ex rental car and stomped the hell out of the floor and it didn't do it so it must just be a defect with a few of the french built 14's or something.
60/40 to Bench Seat Swap Issue CTScott Cosmetic Modifications (Exterior/Interior) 24 11-26-2012 02:45 PM
Feeler: Swap my hatchback 60/40 rear seat for your solid two piece bench rear + cash auxmike Items for Sale by private party 12 11-11-2012 07:52 PM
Rear reclining seat fitment questions vimnjicki Cosmetic Modifications (Exterior/Interior) 3 12-26-2010 02:15 PM
