Old 10-17-2016, 04:17 AM   #1
todorakiggg
Drives: Yaris Hybrid
Yaris DRL Halogen Bulb LED replacement
Hello,
my wife's Yaris has a factory build DRL using however halogen bulbs.
I would like to change the bulbs with plug and play LED replacements.
Does someone know and use LED bulbs which will fit with no issues?
What I was able to find in the owners manuals is that the bulb is Wedge base bulbs (clear), but it has no dimensions no nothing...
All suggestions are welcomed.
todorakiggg is offline   Reply With Quote
Old 10-17-2016, 11:50 PM   #2
SirDigby
Drives: 2007 yaris 3 door
the DRL is the high beam/low beam bulb at low voltage. (in the US) the Wedge bulb is used during normal lights operation. the wedge bulb is a size 194. the high/low is a 9003 or a H4
Old 10-18-2016, 02:44 AM   #3
todorakiggg
Here in Europe, DRL lights are using separate bulbs.
I will give it a try to see if I will be able to find something with Wedge bulb size you gave me.
Thanks for the hint.
Old 10-18-2016, 05:30 PM   #4
Yaris_Om
Drives: Yaris 1.5
i recommend you to use the retrofit projector from the retrofit source
you will get the perfect beam :)
Yaris_Om is offline   Reply With Quote
Old 10-18-2016, 06:56 PM   #5
take a picture for all to see.
Old 10-21-2016, 08:06 AM   #6
todorakiggg
Real picture I can provide later... (the car is with my wife)
So I am attaching a screenshot example from the Yaris manual.
Old 10-21-2016, 02:45 PM   #7
todorakiggg
OK, this turns out to be double filament wedge bulb...
So it looks like, it is type 580 with bulb size 7443. (even though I am not 100% sure)
I am just wondering, why is this info not on the user manual....
Old 10-22-2016, 01:22 PM   #8
SirDigby
oh, I didn't know it was such a new car. the bulbs I gave were for 2nd gen...
Old 10-27-2016, 01:15 PM   #9
todorakiggg
Solution found. These bulbs fitted just perfectly and working very well. Instalation took me 3 mins, plug and play replacement of the factory bulbs and that was all. Quite satisfied with the end result.
http://www.autobulbsdirect.co.uk/744...edge-Bulb.html
Old 10-30-2016, 02:15 PM   #10
todorakiggg
Finally after some reading I have ordered these bulbs.
Installation was very easy, just plug and play, it took me around 3 mins for both bulbs. The result is very, very satisfactory. The light is amazing, no error lights no nothing. Even now I think that the turn signal is more visible, because it is clearly different from the original yellowish DRL light.
As of now I can highly recommend the bulbs, but I got to admit, they are expensive...
Old 11-02-2016, 09:00 AM   #11
todorakiggg
Solution found and works perfectly well.
If someone is interested, please let me know and I will send you more details for the LED bulbs I've used. (I tried twice to post the link here, but I am still waiting on the moderators to approve it, maybe they didn't).
Toyota Yaris 09 REG P2112 - Throttle Body Replacement Help Toastie DIY / Maintenance / Service 13 05-08-2016 04:28 AM
Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal V70R_Blackbrick Cosmetic Modifications (Exterior/Interior) 26 11-27-2013 10:14 PM
2012 Yaris DRL Light Install--Hand Made-- martindimitrof DIY / Maintenance / Service 14 11-21-2012 02:44 AM
