Old 05-17-2007, 02:14 AM   #1
static808
Engineer/Artist/House-Dad
static808's Avatar
Drives: 2006 Toyota Sienna XLE
finally found the 5w-20 TSB...
i was wondering if anyone out there has started using the 20 weight oil, and whether any benefits have arisen?? a few others on different boards have stated decent increases in mpg. unfortunately, i've purchased enough amsoil ASL 5w-30 to last me 2 oil changes, but i'm thinking of switching to their 0w-20 on both my sienna (3MZ) and yaris (1NZ), since both their engines are clearly on the list. should be good timing since gas will probably be around 4 bucks/gallon when that time comes around...
--B
His: 2006 Toyota Sienna XLE Arctic Frost Pearl, FC Package, 2007 Solara Nav unit, Spoiler, Running Boards & Auto-dimming rear mirror
Hers: 2007 Toyota Yaris LB Black Sand Pearl, Auto, Power Package, Side Airbags, VIP security, USDM center armrest, and accessory 7 spoke 15" alloy wheels
static808 is offline   Reply With Quote
Old 05-17-2007, 09:11 AM   #2
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
interesting..this should answer few questions.
should remakte and sticky it.
-- Blen
Old 05-17-2007, 09:32 AM   #3
YamilR
YamilR's Avatar
Drives: Absolutely Red Liftback
Send a message via Yahoo to YamilR
can you post the pdf file for download?
YamilR is offline   Reply With Quote
Old 05-17-2007, 12:16 PM   #4
ChinoCharles
Drives: LB
EDIT: I know BlackYaris is running the 5W-20 water oil that TSB suggests. I make typos too.
Old 05-17-2007, 12:36 PM   #5
esquiva
Noypi ako!
esquiva's Avatar
Drives: 07 S Sedan 5-Speed M/T
0w-20?...doesn't it read that 5w-20 is for our engines?
Nagka-anak sina boy at nene, isang lalaki at isang babae. binata't dalaga na sila...
Nene jr.: tay, peram naman ng kotse o...
Boy Bastos: sige pero isang kondisyon. mag-ano muna tayo.
Nene jr.: tay meron ako ngayon e. blowjob na lang kita.
Boy bastos: o sige.
pagkatapos ng blowjob...
Nene jr.: tay, bat lasang tae yung etits nyo?
Boy bastos: ah ganon ba? hiniram kasi ng kuya
mo kanina yung kotse e!
esquiva is offline   Reply With Quote
Old 05-17-2007, 12:43 PM   #6
i'm running 5W-20 Mobile 1 right now. i've experienced an increase in mpg. and it seems a little smoother.
Old 05-17-2007, 01:21 PM   #7
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
yeah the thing said 5w-20 for our engine
Old 05-17-2007, 02:17 PM   #8
sambo42xa
Drives: 07 YARIS Automatic/LiftBac/Red
(2 post before me....) Read the TSB where it shows/says at the bottom, "oil recommended for these engines". If Your engine code falls in the list, then I do not see a problem using the 0-20 from what I understand after reading static808 TSB.
I will look at my "code" and if it is in the list I will try the 0-20 weight on my next oil change.
static808, I'm curious on the warranty part. There is nothing there. Does this mean NO WARRANTY if you use/change over to the 0-20??
Also, how did you obtain this TSB; something You found online; work for TOYOTA???
thnx.,
sambo42xa
Southern, NH
sambo42xa
sambo42xa is offline   Reply With Quote
Old 05-17-2007, 02:44 PM   #9
jamal1984
our engine code is fall into 5w-20, but if someone else recommended 0w-20 then i guess we can use it, but as far as i see is our engine code is in 5w-20 list.
Old 05-17-2007, 04:01 PM   #10
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
do not use the 0w20 oil. its is not for our motors.......
Old 05-17-2007, 04:23 PM   #11
jmjonesey
jmjonesey's Avatar
Drives: Red 2007 Yaris Sedan
Send a message via AIM to jmjonesey
wow everyone is either totally for it or against it
when will the madness stop!?
jmjonesey is offline   Reply With Quote
Old 05-17-2007, 05:01 PM   #12
Nutzoids
Nutzoids's Avatar
Drives: 07 Yaris Liftback
Found a list of TSB for the Yaris... I just can't look at them...
Unless someone has an ALLDATA login?
TSB Number & Issue Date TSB Title
EL002-07 JAN 07 Charging System - Charge Warning Lamp ON
EL001-07 JAN 07 Electrical - Multiple Warning Lamps/Can't Shift A/T
PA001-07 JAN 07 Body - Replacement Bumper Cover Refinishing
BO023R-06 DEC 06 Restraints - Seat Belt Extenders
PG001R-06 NOV 06 Electrical - Battery Maintenance and Testing
PA002-06 NOV 06 Paint - Stains Under Rapgard (R)
SU007-06 OCT 06 Suspension - Shock Absorber Replacement Criteria
NV009-06 SEP 06 Body - Upper/Lower Windshield Ticking Noise
TC013-06 SEP 06 A/T - Reman Transmission Serial Number Locations
TC012-06 SEP 06 A/T - Serial Number Locations
EG035R-06 AUG 06 Exhaust System - Excessive Sulfur Odor
BO011-06 JUL 06 Interior - Park Brake Lever Boot Catches on Console
NV004-06 MAY 06 Interior - Front Seat Squeak Noise
BO017R-03 APR 06 Body - Interior Trim Panels/Garnish Loose
ST005R-01 APR 06 Steering - Vehicle Pulls To One Side Manual Supplement
*Philosophy of life... Brought to you by... "Nutzoids"
Nutzoids... Where Punk rock is less about Image, and more about the Mind!
Nutzoids is offline   Reply With Quote
Old 05-17-2007, 05:55 PM   #13
jamal1984
the only thing i am really don't understand that is if 5w-20 and 0w-20 is really good for our engine then why don't they listed in our manual but instead of 5w-30?
Old 05-17-2007, 06:04 PM   #14
jmjonesey
jmjonesey's Avatar
What?! you didnt get the e-paper manual? all you have to do is take your manual to the dealership and get the new auto updating manual that keeps up with toyota's changes on-the-fly
Old 05-17-2007, 06:05 PM   #15
jamal1984
No i dind't receive nothing from them.
Old 05-17-2007, 06:08 PM   #16
static808
static808's Avatar
thnx.,
sambo42xa
Southern, NH
i actually found this on my other board, siennaclub.org. people over there are just as torn as people over here regarding switching over or not. im giving it a shot since we all could use the extra mpg, and i just called toyota's customer experience line, and they stated that as long as our engine is listed in the tsb, our warranties will be covered as usual, should anything happen because of the use of 20 weight oil.
with regards to using 0w-20, instead of 5w-20, amsoil only carries an 0w-20, and they state that it is intended to replace conventional 5w-20 as well. they also mention how honda, toyota and gm are starting to recommend using 20 weight oil. its just like their series 2000 0w-30 oil; it is intended to replace 5w-30 oil also. same viscosity characteristics as the 5w's, just better cold weather start-up. an 0w designation also simply means a synthetic formula, since i cant find a conventional-dino 0w oil. its odd how this tsb actually "unofficially" has toyota endorsing synthetic oil use. i dont want to start another convetional vs synthetic debate, but i just wanted to post this thread out there for people who had heard of this tsb but actually could never find it. now we can all start getting better mpg without wondering whether using this weight oil will adversely affect our engines... hope this helps!
--B
Old 05-17-2007, 06:10 PM   #17
static808
static808's Avatar
here ya go...
--B
Old 05-17-2007, 07:54 PM   #18
drifto
drifto's Avatar
Drives: 07 5spd Yaris LB
Send a message via MSN to drifto
TSB's are the most current info for our car supplied by toyota. sometimes the manufacturer may find something that is better for or car or fixes a common problem in our car. things are constantly updated due to common customer complaints etc. the TSB's are the most up to date information so they superceed any info in our owners manuals. the techs use them everyday to repair and service our cars. thus any info in the owners manual can be updated at any time. dealerships usually make the updates automatically when you bring your car in for service. sometimes you have to ask though...
th
sambo42xa
Southern, NH
there is no warranty info b/c its only updating the grade of oil used during an oil change at the dealership. oil changes are not warranteed. if it were say a defective radio unit. then you would see warrantee information explaining that a new unit is under warrantee etc. hope this helps explain things a little.
Going from drift to grip...
07 Yaris LB 5spd
AE86 Corolla GTS 5spd
http://microimage.ning.com/
http://www.microimageonline.com/store.html
drifto is offline   Reply With Quote
TSB for steering pull? vst DIY / Maintenance / Service 12 06-09-2007 02:40 PM
Finally! KittenRD New YARIS Purchase Forum 6 01-01-2007 09:16 PM
Finally installed oem ebay fog light for hatchback Adriaan General Yaris / Vitz Discussion 6 12-27-2006 04:24 PM
finally found a good product to clean al plastic parts Adriaan Wash, Wax, Detailing, Exterior Repairs 4 12-01-2006 02:45 PM
It's finally here! Cathy New YARIS Purchase Forum 10 08-29-2006 10:08 AM
