#1 |
![]() ![]() ![]() Drives: 07 yaris hatchback Join Date: Dec 2016
Termostat won't open??? O7 YARIS H.B
So I randomly grab the bottom radiator hose after 30 minutes commute so was cold so I got a new termostat but is doin the same after goin to Gillette stadium is like 1 hour drive still won't open it got heat and won't overheat ?????
Sent from my SM-G935T using Tapatalk |
how cold is it outside?
#3 |
#4 |
![]() ![]() ![]() Drives: Yaris T-Sport Join Date: Nov 2016
So 1.6°C ... i assume you have proper amount of glycol in your cooling system .... and if not it still won't freeze on that temperature anyways :/
#5 |
Is the upper hose hot?
Coolant returns into the engine down there so it's possible it's been cooled down by the rad to the point of not feeling hot anymore. |
#6 |
![]() ![]() ![]() ![]() Drives: 2010 yaris 3 door hatch Join Date: Jun 2013
The top one should be the hot side. One these engines, when the t stat opens, it lets coolant into the engine.
#7 |
![]() ![]() ![]() ![]() Drives: 2007 2-door hatchback Join Date: Jul 2016
Thermostat heater cooling system temperature gauge.
The cabin heater is also a radiator cooling the system coolant. I would like a temperature gauge. My 1989 Tercel temp needle ran high for awhile. Then, I'm guessing, the thermostat or some blockage unstuck and it ran dead center again. Then the needle ran low and I stuck some cardboard behind the grille. And then got normal again. (Note: approach to non safety-critical items evolved as death-by-rust-inspection approached.)
But this dual-idiot-light-no-gauge approach of Yaris gives no such ability to track trends enough before extremes. Last edited by dogsridewith; 12-18-2016 at 11:57 AM. |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
What others have stated above. Check the top hose, it has cooled down enough by the time it reaches the bottom hose as well as through your heater core.
I find the 1nz cools very efficiently when outside temps are low
No one ever wants to give a Yaris the point by... ![]() |
#9 |
And forget to mention ... malfunctioned radiator cap causes that kind of problems !
#10 |
![]() ![]() Drives: 2015 yaris L Join Date: Jun 2016
If you have drained coolant recently, you may not have gotten all the air out of system?
#11 |
#12 |
#13 |
#14 |
Is overflow tank at correct level? Do you get illumination of the high temperature indicator lamp?
#15 |
#16 |
Drives: 07 Yaris Sedan Aero Join Date: Oct 2006
You are saying you are not getting heat inside the cabin?
The heater core could be blocked.... Sent from my SM-G930W8 using Tapatalk |
#17 |
#18 |
lower radiator hose temperature coolant thermostat heat heater
We ALL now need to be curious and check the operating temperature of the fleet's lower radiator hoses...noting, at mimimum, ambient temperature.
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
Natural Gas Yaris | MadMax | General Yaris / Vitz Discussion | 13 | 06-03-2017 06:10 AM |
Do you like the 2012 restyle? | hitmoninfinity | Third Gen Yaris General Discussion | 106 | 04-14-2016 08:08 PM |
Who remembers the SoCal H.B. Yaris meets? I've got pics... | ern-diz | California | 3 | 04-27-2015 11:18 AM |
2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 04:54 PM |
