Old 08-02-2017, 04:08 PM   #1
theb
Drives: yaris
Yaris 07 oil type
I have Yaris 2007 and been using Shell 5w30 since I had my car. Yesterday I went to my local shop where I've been customer for 8 years. They don't sell this type of oil any more and they offered me Klondike 5w30 Synthetic.
I asked the guy if switching to this one will have any issues or problems he of course said no so I bought it.
Thought about it and said it's probably better to check with somebody if I should do this or not.
Called Shell customer service to ask them where here in Vancouver, BC can i buy their oil and it was a pain because the guy was from Houston TX and had not much idea where Vancouver BC is. I told him well I called the number that is listed on Shell.ca and he replied that they cover Canada as well. Anyways he couldn't help.
Called Toyota customer service, lady was doing her best to help for about 15 minutes putting me on hold to check with managers and technicians. Came with the answer that any 5w30 would be fine. After asking her about the synthetic oil she paused (she probably had no clue what to answer me about this) but was probably tired checking with her managers etc. After all she apologized for not being able to get me the right advice.
She did say to take old can and go to local Toyota dealer and they will able to help me. ( Not a bad idea but... I just need to buy some motor oil????)
Called my local store where I purchased Klondike oil. Told him about potential issue switching to synthetic oil and not having possibility to go back to Shell oil. He said I am not sure that a car engine would be able to tell the difference between synthetic and non synthetic oil.
Any advice from here?
theb is offline   Reply With Quote
Old 08-02-2017, 08:46 PM   #2
IMO it doesn't matter. Although, some say synthetic have cleaning properties, so after switching to synthetic, the engine might start consuming oil as it cleaned out the junk in there.
Honestly I don't think it has any effect for an engine that don't require synthetic oil. So as long as the oil grade (5w30) is correct, you are good to go.
Not sure where you live in BC, but shell oil is available at Walmart or CanadianTire. Stock may vary though.
Sent from my SM-G930W8 using Tapatalk
Old 08-04-2017, 02:18 AM   #3
rabbito
rabbito's Avatar
i use 5W30 synthetic too...last oil change they only had shells 5W20 synthetic oil so i had no choice...no issue at all...
factory requested 10w30 mineral oil but it doesnt really matter....i like to hit red line so synthetic is way to go
Sent from my SM-N920C using Tapatalk
Cosmetic: Toyota red emblem
car, oil
Oil pan heater for the Yaris David C Fuel Economy Forum 18 02-11-2017 12:11 AM
Yaris Tranny Oil Question. mario98c Performance Modifications 9 12-18-2012 07:09 PM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Used Oil Analysis : 2010 3 door Yaris : 4,341 mis. on oil and 16,611 miles on engine Hershey DIY / Maintenance / Service 22 08-04-2011 10:52 AM
