Old 08-18-2017, 01:46 AM   #1
Tn09yaris
Drives: Toyota Yaris Hatchback 2009
Unhappy USB port install in center console - 2009 Yaris hatchback
I have an 09 Yaris hatchback. To the right of the emergency brake in the center console there are four accessory ports. Currently I have a factory installed aux port and automatic dork locks taking up two of them. The other two are empty. I want to install a USB port in one of the empty blanks to use for charging (NOT for music).
I've found an oem dual USB port charger for use in Toyota cars that I can tell is made for the ports in my car, but do not know how to go about installing it properly, and after extensive searching for help videos/articles online with no avail, I've come here for assistance. Any help or suggestions would be appreciated. From the look of the item, I think it's a simple red/black (hot/ground) wiring solution but I'm not sure. Thanks!
The USB charger can be seen here: https://www.ebay.com/itm/252574886831
Tn09yaris is offline   Reply With Quote
Old 08-18-2017, 07:15 PM   #2
hotracer_05
Hmm, I see...
hotracer_05's Avatar
Drives: 2012 Toyota Tundra and Yaris
if you want it to only be on, find a constant hot or run directly to the battery (install a fuse). If you want it to only be on when the key is in, find an acc wire and tap in
"Everything happens for a reason. Sometimes that reason is you're and idiot"
hotracer_05 is offline   Reply With Quote
Old 08-29-2017, 12:16 PM   #3
GibbsYaris07
Drives: 2007 Toyota Yaris 3dr
I'm going to attempt this mod as well. It could be convenient to install a usb charging station there with a short plug since phones could fit in the rectangular opening near the brake.
The Gibbs Garage
2016 Lexus GS350 f-sport (my main car)
2013 Lexus RX350 (wife's vehicle)
2010 Toyota Tacoma (my second vehicle)
GibbsYaris07 is offline   Reply With Quote
Old 10-01-2017, 05:45 PM   #4
Be_Jammin
Drives: 2010 Yaris Liftback A/T
Did anyone attempt this? can you post pics / a walk through of how you did it?
Be_Jammin is offline   Reply With Quote
Old 10-02-2017, 06:54 AM   #5
2slowjetta
Drives: 2013 yaris
Diy Bump
2slowjetta is offline   Reply With Quote
Old 10-02-2017, 08:20 AM   #6
nortonfb
Drives: 2007
No pics but easy install.
Remove center counsel. One bolt and I removed shift knob to get it out of the way.
I ran ground wire to one of the bolts under counsel. The other went to the radio
accessory wire (pink?).
I bought on ebay a usb port that was made for Toyota. It had two blue leds in it.
Fits fine, looks neat when lit, good quality and it's fused. All for less than $5 USD.
nortonfb is offline   Reply With Quote
Old 10-02-2017, 12:17 PM   #7
hairygityeti
Sir Rustalot
Drives: Toyota Yaris silver 2000 reg
I need one too,should be easy enough
If it wasnt for my modesty ,i would be perfect !
hairygityeti is offline   Reply With Quote
charger, install, phone charger, usb, usb port
Is there a center console available for 2015 Yaris Hatchback? OGHUGO Third Gen Yaris General Discussion 16 12-18-2015 04:23 AM
Steps to install a subwoofer in Yaris 2008 HB eepp In Car Entertainment + Electronics (audio / video / alarm) 2 11-20-2013 07:30 PM
