Old 10-22-2017, 09:18 PM   #1
ACKING_QC
ManualTransmissionLearner
Drives: 2018 VW TSi Stage1
VERTICAL rear wiper for.. every hatchbacks EVER
yep you read the title right, I did that on my Yaris... that had quite a lot of changes during the summer, have a look at its butt
it's actually the simplet thing EVER to do....
ACKING_QC is offline   Reply With Quote
Old 10-27-2017, 05:20 AM   #2
vivalaflam
Enthusiast
vivalaflam's Avatar
Drives: 07 Yaris HB 1.3 (EU)
That's exactly what I want to do with my new spoiler as well, but with the hydro dipping technique. Could you please post a step by step guide for the wiper? Cheers
Cheers, George.
vivalaflam is offline   Reply With Quote
Old 10-27-2017, 09:57 AM   #3
ACKING_QC
well in reality you don't need to be MacGyver to do that,and you can work IN the car sitting in it... all you need to do is :
1. remove the back plastic panel
2. you will see a piece of metal with 4 + patern screws and 2 (or 3 Idon't remmember it right) 10mm bolt......undo all this and be carefull when removing this plate because some pieces can stick to it due a big amount of grease
3. once this thing is out, you will see a dented gear with 4 holes and if nothing stuck to the plate you removed, another rectangular plastic piece in one of the 4 holes... the thing to put it vertical is to get it out of there and put it on the one to the LEFT... tho I could be wrong so test with the 4 holes and see how you want it....
4.re assemble it all and BOOM vertical wiper
as for the spoiler. YEAH ! go hydro-dip (I might do that as well) because this is INDIVIDUAL STICKERS..... and the sun destroyed the colors even with 4 coats of EXTERIOR PAINT clear.......
Old 10-27-2017, 01:18 PM   #4
kimona
kimona's Avatar
Drives: 2014 White VITZ
I don't get the VERTICAL rear wiper. Why?
Old 10-27-2017, 03:11 PM   #5
dogsridewith
Drives: 2007 2-door hatchback
spoiler looks like a kindergarten paper mache project
Old 10-27-2017, 03:39 PM   #6
heeroyuy01195
Post count means nothing.
Drives: AW11, NCP91, Old Motorcycles
This. I don't really see the point in the vertical wiper? Is it a fashion thing?
heeroyuy01195 is offline   Reply With Quote
Old 10-27-2017, 04:11 PM   #7
One reason, for those living in lands of ice and snow, is to eliminate the winter issue of snow/slush, and ultimately ice from building up on the wiper blade and arm.
Old 10-27-2017, 05:34 PM   #8
kimona
kimona's Avatar
That makes sense. I get it now.
Old 10-27-2017, 05:51 PM   #9
ACKING_QC
yep! common mod in japan but isn't standard on every snowy/icy places.... should be tho !
Old 10-27-2017, 05:52 PM   #10
ACKING_QC
I took the pic in a hurry, it actually isn't that bad... even if the sides are completely fucked up !
Old 10-28-2017, 02:07 PM   #11
dogsridewith
Vertical rear wiper modification Toyota Yaris
I like the mod, but have no rear wiper/washer. Was going to mention that the horizontal one on a 91 Corolla wagon holds tree debris, road dust, snow and ice and salt...bleeding it off slowly so that it can best rust out features below it.
Much of my driving is short trips on dirt roads, and that rear window is a real dust magnet. I find that a hand pimped water spritzing bottle makes a sufficient cleaning for vision purposes, w/ surprisingly little water and with no squeegee/cloth etc. to keep clean enough not to scratch glass and need drying between uses ,etc. Best/easiest results in am when window is wet w/ dew.
Old 10-30-2017, 02:11 PM   #12
heeroyuy01195
That makes perfect sense now. No snow where I'm at thankfully
Rear wiper motor removal KenTK808 Third Gen Yaris General Discussion 9 12-09-2019 08:06 AM
Removing rear wiper fred812 Cosmetic Modifications (Exterior/Interior) 34 01-27-2013 12:22 AM
Rear wiper: EZ mod so it pulls back all the way joelitton Cosmetic Modifications (Exterior/Interior) 10 10-22-2008 10:30 AM
Rear wiper function, is this normal? Yaris Dick General Yaris / Vitz Discussion 7 11-08-2006 09:46 AM
