Old 02-17-2018, 08:07 AM   #1
Pinchlite
Drives: 2007 yaris HB
Quick question regarding longer rear studs.
From this thread I may have a problem?
http://www.yarisworld.com/forums/showthread.php?t=13115
Here is my 10mm spacer with extended studs.Specifically made for my model yaris https://i.imgur.com/ljGTDnp.jpg
Question is will I be able to slide these studs in without having to dismantel the whole rear assembly?
I was hoping they would be slide in from the back?
Pinchlite is offline   Reply With Quote
Old 02-17-2018, 09:32 AM   #2
You do not need to disassemble anything.
Old 02-17-2018, 09:56 AM   #3
Pinchlite
Perfect!.. and thanks for reply.
The thread link made it sound like there was not enough space to slide longer studs into place.
Old 02-17-2018, 11:01 AM   #4
If your new studs are not any more than 10mm longer than the factory studs you will be fine. Any longer than that and space behind the stud plate does become an issue.
Need longer wheel studs Decieved Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 02-05-2016 11:36 AM
rear beam question: one wheels sticks out more DINOeggxo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 58 05-10-2014 10:38 PM
Longer wheel studs for 5mm spacer? Captain Slow Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 02-09-2013 10:35 PM
Quick question.. harveyjai Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 03-21-2009 05:38 PM
Stupid question...TRD Quick Shift Stargate YARlantIS DIY / Maintenance / Service 17 11-30-2008 11:46 PM
