Old 04-25-2018, 03:18 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Spacers have arrived!
Very happy to receive a Canada Post notification that my parts have arrived. Thanks, invader166! Loved the 'refreshing looking' shipping box, too!
The 08 goes into the shop tomorrow to get the H&R 10 mm spacers put on. Here's hoping the longer studs will go in without having to remove the hub. Fingers crossed. If hub removal is necessary, it will just be good paractice for putting the Penguin spacers on the '06, which is the next job.
Old 04-25-2018, 03:26 PM   #2
Beauty. Supplied studs appear to be of a length that will not cause issues when it comes to putting them in there.
Old 04-25-2018, 03:37 PM   #3
06YarisRS
So awesome. Hang tight. I'm going to add a pic of the studs to give you a better look.
Pic... Can you confirm WeeYari, that these will indeed go in without removing the hub? Of course, I won't hold it against you if I can't get them in due to my mechanical ineptitude, LOL! Not sure what the longer greyish bolts on the right are for.
Old 04-25-2018, 03:38 PM   #4
Don't need one. Can clearly see they are a good length.
Old 04-25-2018, 03:55 PM   #5
06YarisRS
So, if all goes as planned, I'll have some before and after pics tomorrow. Thanks!
Old 04-30-2018, 04:26 PM   #6
06YarisRS
Spacers installed
I made a collossal screw up. After removing the drum to replaced the studs, I forgot to replace the drum and attempted to install the spacers directly to the wheel hub. Anyway, I had to machine lathe out a bit of the lip inside the spacer bore to make it fit I wasn't thinking. Bolted it all back together and went for a drive. It drove fine, but had an almost imperceptible bit of wheel wobble when looking at it in the mirror. Back to shop, realizing what I'd done and put the spacer outside this time. I hadn't removed enough material to make the hub bore loose. The other side, I did properly.
The studs went in easily with a bit of fiddling.
On to the pics. Although they don't show the difference really well, in person it does look much better and more obvious.
3 new long studs installed. Rear brake job tomorrow. :)
Top, before spacers, bottom after...
Old 04-30-2018, 04:34 PM   #7
kimona
kimona's Avatar
Drives: 2014 White VITZ
Yup. Noticeable difference.
Old 04-30-2018, 06:00 PM   #8
06YarisRS
Haha, glad someone else could see the difference. The kids in the shop all laughed that someone would put spacers on a Yaris. Of course, they're mostly into big off-roading trucks and such and only feel that such vehicles deserve spacers.
The '06 will be getting its Penguin spacers installed in a few weeks.
Old 05-01-2018, 04:50 PM   #9
Old 05-01-2018, 04:58 PM   #10
06YarisRS
No s**t, eh? LOL!
Old 05-02-2019, 05:53 PM   #11
Tskm2
Drives: Yaris hatchback 06
Possible to take measure of length of stock wheel stud? On rockauto they have one with 40mm tread length. I need 8stud with only 2mm more length. The wheel i buy the hub was too thickness
Tskm2 is offline   Reply With Quote
Wheel hub spacers be warned! tmontague Performance Modifications 17 07-07-2016 09:56 PM
PG Hub spacers group buy Vitz_Q8 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 45 11-15-2015 02:10 AM
FS: Hub Spacers (R) /Wheel Spacers (F). Come with extended bolts. Betrivent Items for Sale by private party 1 06-26-2015 10:41 PM
Wheel spacers walkthrough :) Lars Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 06-05-2014 08:49 AM
Installed 10mm PG spacers on a 15x7 +25 wheel kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-27-2009 07:10 PM
