Old 02-16-2019, 10:23 AM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Installed TRD Swaybar Today
The bar has been sitting around my dining room for a couple months now and since it was relatively warm today, I thought I'd throw it on. Unfortunately, it will be a couple more months before I can experience the handling improvement.
The installation was a snap. The shock bolts came off fairly easily with my electric impact gun, largely due to the rustproofing that I do regularly. I did blast the bolts with some ReleasAll about 1/2 hour before. This bar could easily have been installed with the wheels on as mentioned in another post, but I thought I'd take them off anyway.
Bolts removed:
Got this tip from another post. Install back bolts first, then roll the bar forward into position and install the front bolts. Makes for a very easy install:
Lots of antiseize.
I dropped the torque of 36 and 40 ft/lbs a touch to compensate for the antiseize:
Wheels back on:
Old 02-16-2019, 10:32 AM   #2
Nicely done, now to wait around for spring to test it out...
Old 02-16-2019, 10:49 AM   #3
06YarisRS
Haha, yeah. Gonna be tough to wait. But, it does give me time if I decide to do another project.
Looking at your sig pic, it looks like you did eventually install the engine stay. Also, catch can setup looks great.
Old 02-16-2019, 11:50 AM   #4
Good you have time for rustproofing. My sway bar is pretty much all rusted now :)
Sent from my CLT-L04 using Tapatalk
Old 02-16-2019, 01:38 PM   #5
06YarisRS
Yes, rustproofing ranks high on my maintenance list.
I thought about painting the swaybar black but pretty sure primer and paint doesn't really adhere well to powder coat. When it does get chipper and start to show early signs of rust, I will paint it in a nice satin black.
Old 02-16-2019, 01:39 PM   #6
Wanna trade with mine? It's probably not red anymore lol
Old 02-16-2019, 03:41 PM   #7
06YarisRS
Sure, why not. Paint would probably stick to yours better.
Old 02-16-2019, 08:41 PM   #8
That is an old pic, I have a much cleaner and proper occ now. I'll update my pic but the engine bay is no where near that clean anymore...
Old 02-18-2019, 12:30 PM   #9
06YarisRS
Look forward to seeing it.
Old 04-21-2019, 09:56 PM   #10
bluefever00
Drives: 2008 Sedan
Pardon the newb question, but did the yaris come with a rear sway bar from the factory? I haven't looked under mine and it's dark right now. If so, is it larger than the original?
bluefever00 is offline   Reply With Quote
Old 04-21-2019, 10:14 PM   #11
No it doesnt. The rear suspension is an H beam design which is a semi independant system. A rsb actually makes it act more like a solid axle fully non independant suspension. It will feel more solid on the highway and slightly increase oversteer but when pushed to its limit the rsb will actually become detrimental to grip
Old 04-22-2019, 07:28 PM   #12
Tskm2
Drives: Yaris hatchback 06
From where you buy? Direct from dealer?
Tskm2 is offline   Reply With Quote
Old 04-22-2019, 09:13 PM   #13
06YarisRS
I shopped around for a while for the best price. I bought it from a Toyota dealer in California, iirc.
TRD exhaust hanger issues....check yours Gogogordy DIY / Maintenance / Service 4 11-08-2012 07:22 AM
Installed struts, shocks and springs today.. and mebbe a problem... SKurj DIY / Maintenance / Service 3 05-07-2011 09:37 PM
TRD Sport Suspension installed! Hard_Yaris DIY / Maintenance / Service 6 10-24-2010 06:51 PM
Pics of New LED Tail Lights Installed Today theconspiracymarket Cosmetic Modifications (Exterior/Interior) 8 08-03-2010 11:14 AM
Are my trd springs installed upside down? YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 11-17-2008 11:12 PM
