Old 04-26-2019, 02:13 PM   #1
TypeReaL
Drives: 2006 Yaris Hatch
Exhaust mani removal issue
Hey, folks Im working with an 06 yaris and recently bought an ebay header as my factory manifold was cracked ive gotten every bolt out minus the 2 on the bottom of the factory manifold they are so rusted both of them rounded and with the way the pipe bends I am having a hell of a time getting them out has anyone ever had similar situation
edit have used attempted to get easy outs in but the pipe essential makes it go on an angle and i cant get a clean turn on it
TypeReaL is offline   Reply With Quote
Old 04-26-2019, 02:32 PM   #2
If easy out sockets dont work (use alot of pressure) then cut the bolt head and then weld a bolt onto the rest of the stud, or try vice grips on that stud when the manifold is removed
Old 04-26-2019, 11:30 PM   #3
TypeReaL
will def try that ty vm
Old 04-27-2019, 12:04 AM   #4
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Experienced the exact same issue with my '06. I farmed that job out. I think the guy may have unbolted the rear engine mount, removed the axles and tilted the engine forward. He did as Trevor said - welded nuts onto the studs, worked them back and forth with heat to get them out. One of my axle seals got damaged in the reinstallation process, but he came good and replaced the seal sans charge.
Old 05-01-2019, 04:36 PM   #5
TypeReaL
After much heat and removal of the axle which ill tell you the mess with that I did manage to get it out and remove the o2 sensor which seemed to be cross threaded into the stock manifold as if to prevent reuse could be crazy but i doubt its ever been off.
Now when the axle nut came about half way The impact went from full spin to wow thats spinning slow come to find the threads stripped and right near the splines you could see where it turned blue from being so hot but all and all everything goes back in tomorrow when the parts store has the new o2 thanks for all the help fellow yaris enthusiasts ! now the header is done there is more to come :D
FS: Tanabe Medallion axle-back exhaust Samantha0716C Items for Sale by private party 11 06-15-2018 10:16 AM
Please help with exhaust 06YarisRS DIY / Maintenance / Service 10 10-03-2017 12:04 PM
Exhaust Manifold to Pipe Donut Gasket yarisinpa DIY / Maintenance / Service 1 06-29-2017 03:35 AM
Exhaust manifold damaged by corrosion donpalino DIY / Maintenance / Service 5 05-26-2015 04:38 PM
yaris voltage issue yaris2010RS DIY / Maintenance / Service 11 12-29-2012 04:20 PM
