07-20-2019, 11:57 AM | #1 |
Fugitive
Drives: 2007 Yaris 4 Door Hatch Join Date: Jul 2014
Hybrid system goes off
Hello all,
I have a 2012 Yaris 1.5L Hybrid, I have just purchased this vehicle from another guy near my town. I am facing a strange yet weird issue in the car, whenever there are 3 or more persons in the car, suddenly the car's hybdrid system goes off and the car goes to safe mode and runs only on gasoline, then I have a disconnect the battery terminal grip for few minutes to reset the ECU. I am attaching the pic of the speedometer as well. Sent from my ONEPLUS A5000 using Tapatalk |
07-20-2019, 02:17 PM | #2 |
Drives: 2016 SE Join Date: Nov 2015
we are not fortunate enough to have the yaris hybrid here in the us for well understood reasons
dont get me started! good luck with the car! |
07-21-2019, 07:13 PM | #3 |
Drives: 07 Yaris Sedan Aero Join Date: Oct 2006
You seem to have a CEL as well. Perhaps you should get it scanned to know why you get this issue.
Sent from my CLT-L04 using Tapatalk |
07-22-2019, 06:54 AM | #4 |
Drives: Yaris Join Date: Feb 2019
Do you happen to have the AC on ? What do you mean safe mode ?
Once you pull away and get above 25-30 MPH or give it more than 15% throttle the engine will kick in, The engine will start if you have the AC on or it detects the car needs more power or the battery pack is low Look at the animation on the screen it tells you the battery state and power distribution Once the car is in ready mode, Do the lights (symbols) on the dash go out (self check) Is this your first hybrid ? There may not be an issue at all just you may need to change your driving style The Hybrid is a good little car - It has the eCVT, not a standard CVT (belt driven) what you find in a standard Toyota Auto (non hybrid) |
07-22-2019, 11:04 AM | #5 |
Drives: 2019 Yaris HSD Join Date: Jun 2019
From the vehicle's manual:
Hybrid system warning light (warning buzzer) Indicates a malfunction in the hybrid system. Immediately stop the vehicle in a safe place and contact any authorized Toyota retailer or Toyota authorized repairer, or any reliable repairer. Apparently there's something wrong with the hybrid system. Nothing to do with the way you drive... |
09-29-2019, 03:59 PM | #6 |
Drives: 2013 Hybrid 1.5L T4 Join Date: Jan 2011
Would be nice to post An update of your final findings mate for others to learn
10-01-2019, 02:11 PM | #7 |
Yaris Hybrid Limited 2015
Drives: yaris Hybrid limited 2015 Join Date: Mar 2012
If it isnt solved yet, it could be as simple as the filter for the cooler fan for the hybrid battery need a cleaning.
Yaris Hybrid Limited 2015 C-HR 1,8 Hybrid premium 2020 |
Similar Threads | ||||
Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
ACRONYM thread | Shroomster | Off-topic / Other Cars / Everything else Discussions | 44 | 08-23-2014 03:55 PM |
Ohm's Law and Setting Amp Gain | _S7V7N_ | In Car Entertainment + Electronics (audio / video / alarm) | 24 | 03-13-2012 09:34 PM |
2012 Camry | Kal-El | Off-topic / Other Cars / Everything else Discussions | 26 | 10-02-2011 09:20 PM |
NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
