Old 01-03-2021, 03:07 AM   #1
JB91
Drives: 2015 Yaris NCPR130
Blackening the badges
Hi all,
I would like to remove the badges so I can spray them black. How easy is it to remove them and then put them back?
I'd rather remove them so I don't get spray where it shouldn't be.
JB91 is offline   Reply With Quote
Old 01-04-2021, 04:53 AM   #2
goldbug
goldbug's Avatar
Drives: yaris hatchback
JB91:
I used an expired plastic membership card. The thickness of the membership card was smaller than the thickness of a credit card. With that plastic membership card, I slid it behind the emblem and it cut through the sticky tape like cutting butter. Dental floss doesn’t do it in MO. After the emblem was removed, it was just a matter of cleaning up the residual glue. I’ll be doing the second emblem badge next weekend. Good luck with your project!
goldbug is offline   Reply With Quote
Old 01-05-2021, 01:35 AM   #3
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150
Get a hair dryer or heat gun and warm it up before you try and pry it off, it'll make it easier.
The front emblem is held on with tabs, I managed to just yank mine off when I swapped it out for the Netz badge.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 01-12-2021, 06:14 AM   #4
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Putting them back on involves cutting many small pieces of 3M or other high quality 2-sided tape. Definitely not difficult, just finicky. There are some pics to give you an idea in this thread:
https://www.yarisworld.com/forums/sh...light=liftgate
I think there are some liquid types of adhesive that might be easier and less time consuming, but I'd want to be sure that they did damage the paint, or make them too hard to remove later if you had to remove them.
Old 01-18-2021, 01:35 AM   #5
goldbug
goldbug's Avatar
I used 3M tape on some badges. I also used the Clear Silicone Rubber seal that’s normally used for House Doors and Windows on other badges. The house silicone rubber seal worked great on the badges! Make sure you clean up the excess silicone. Here’s is a pic of a tube of clear silicone.
File Type: jpg B05E7377-F3BC-4204-8CDD-4F868C20D77D.jpg (205.7 KB, 80 views)
Old 02-23-2021, 11:16 AM   #6
Neinris
PLASTIDIP
Is the rear badge tacked in with tabs also or is it just taped on? I thought about "plastidipping" my rear badge and emblems, but now I'd like to see how yours would turn out first. For the front badge, you'd have to remove the bumper to safely remove it. it's not all that hard to remove the bumper.
Vitz badges Thebigwicks Willing to Buy by private party 1 08-08-2015 02:10 PM
Hybrid Badges Nips Cosmetic Modifications (Exterior/Interior) 21 02-10-2012 08:38 AM
Netz/Vitz Badges from Thailand (Pics) Kiteless Cosmetic Modifications (Exterior/Interior) 12 07-07-2011 09:11 PM
[Recovered] Group Buy for Australia #1 (Badges) harveyjai Australia 9 12-13-2008 03:59 PM
Where can I buy badges? ||)) (o) ||\|| Cosmetic Modifications (Exterior/Interior) 2 09-25-2007 12:59 PM
