Old 05-02-2021, 05:55 PM   #1
PureDriversClub
Drives: 2005 Toyota Echo
Question +30 Offset, recommended washer size for camber?
Hi! I recently picked up a NCP91 TRD Turbo M, and I have installed Advan Racing RC-II 16x7 +30, 205/55/16
For the fronts I will be using 15mm Camber Bolts
But i've read the sticky regarding rear camber and about putting washers between the axle and hub on the lower bolts to induce camber.
Is there any recommendation on what size washer would be ideal to get slight camber on the rear? Ideally 20mm offset difference?
Or are there some sort of shims which are better than using washers? (I can't get anything in google that clarifies)
PureDriversClub is offline   Reply With Quote
Questioning the Recommended Tyre Widths based on Offset Energiser Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 02-24-2012 10:32 AM
Bolt Pattern Size and Offset for the Stock Wheels fmicle Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 08-12-2009 03:35 PM
Whats the highest offset and tire size for 17s you could go... YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 12-15-2008 09:40 AM
Transmission Drian Bolt washer size CB900F2 DIY / Maintenance / Service 14 12-07-2008 07:03 AM
