Old 08-25-2021, 11:18 PM   #1
YodaBird
Drives: Gray
Fuse Box cover for hardwire kit ?
The fuse box which is located below the drivers side, there is a hardwire kit which I need to plug into this fuse box; there is no way to replace the cover as to keep it from the fuses becoming wet ?
YodaBird is offline   Reply With Quote
Old 08-26-2021, 08:06 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Could you share a picture of what you have and the problem it's causing?
Old 08-26-2021, 08:11 AM   #3
YodaBird
Drives: Gray
Fifth video from the top; I want to plug in a hardwire kit but the cover will not go back on when this wire is plugged into one of the fuses ?
Old 08-27-2021, 03:24 PM   #4
CrankyOldMan
I thought you meant the one under the bonnet on the driver's side. Unless you've got a LOT of water splashing around down there, I think you'll be OK. The Echo has its main body ECU/junction/relay/fuse box in the same location and none of the fuses on that are covered.
Old 09-03-2021, 10:16 AM   #5
YodaBird
Drives: Gray
How do I know which fuse gives continuous power, even when the car is not on; for the fuse box under the bonnet of the drivers side ?
Old 09-04-2021, 04:02 PM   #6
CrankyOldMan
Looks like everything in the fuse box under the bonnet is powered all the time.
If you're going to be doing electrical stuff on the car, an electrical meter is invaluable. Even a cheap battery powered one with an analog display or the free ones from Harbor Freight are fine for determining if there's power or not. That helps with chasing down electrical shorts and making sure your ground wires are actually grounded.
Old 09-04-2021, 08:22 PM   #7
YodaBird
Drives: Gray
Thanks for the info.
Free electrical meter from Harbor Freight ?
When there is a wire, which is suppose to connect to any metal in the car, I assume that metal can be around the fuse box as well ?
Old 09-05-2021, 11:20 AM   #8
CrankyOldMan
Our version of Princess Auto or Canadian Tire sometimes has coupons for a free tool (flashlight, screwdrivers, multimeter, etc.) in their flyer.
Correct, the negative terminal on the battery or any bare metal should be the "ground" potential. There's no ground reference inside the fuse box, typically it's a local point on the chassis that looks like a beverage can tab screwed to the metal. Toyota's ground wires are usually white with a black stripe or just brown.
The large black or white wires bolted to the side of the fuse box are live from the battery and provide power to all of the fuses. Even the empty fuse slots can be used with a fuse tap, just make sure you have it oriented correctly and the power goes through the fuse in the tap, not directly to the tap wire.
Hydrodipped bezel, engine cover, fuse cover z0mb13k1ll Cosmetic Modifications (Exterior/Interior) 5 05-09-2016 10:39 PM
Fuse box Cover / Bin Craig W DIY / Maintenance / Service 2 02-08-2016 10:09 PM
Wtb driver side fuse cover bin and sun visor clips Creepin Willing to Buy by private party 3 02-07-2016 11:02 PM
Two amps one fuse? And hu install? FuuFuu In Car Entertainment + Electronics (audio / video / alarm) 4 12-24-2011 11:33 AM
Toyota Echo or Scion Xa/Xb for aftermarket HU receiver kit? ceboyd In Car Entertainment + Electronics (audio / video / alarm) 7 12-08-2006 02:13 PM
