Old 05-10-2022, 12:15 AM   #1
E34_Guy
Love my little blue egg
Drives: Yaris 3dr 5sp, bmw E34, E30
Exclamation Front control arm bolt spinning
Rusty Subframe Captive nuts
I didn't plan for this to be my first post, but there's not enough info out there on this topic.
If you're living in 2022 and you have an NCP91/XP90 or 2nd Gen Yaris in North America where we have snow and salt, This is definitely something you should be concerned about.
This is the second time I'm dealing with this issue. The first time, I was trying to unbolt the control arm to pull out the driveshaft to change the output shaft seal on the transmission. Needless to say, I never got to changing that seal as this new problem arose.
The front control arm bolt that runs longitudinally is secured by a "captive" nut that is buried INSIDE the front subframe/crossmember. Meaning that if the bolt is rusty at the tip, it may start coming out without any issue, but as soon as the threads start reaching the end of the bolt where it may be rusty, friction on the nut increases and you run the risk of completely destroying the small metal cage that holds these nuts in.
So you're probably here because your bolt is spinning and not coming out and you want to know how to fix this seemingly impossible problem.
Tools needed:
Mig Welder or Stick Welder (I use a Lincoln Electric mig 250)
Sturdy Vice Grips
Angle Grinder with healthy wheel
Steady hands, and some patience
First up you want to cut into the subframe and make an access panel to get to the rusty carnage that lies beneath.
Use the vice grips to pull/peel the metal back giving you access to the nut.
This ended up not being enough access to the nut, and I had to cut even further into the subframe
Once you're able to get some good access to the nut, you'll be able to see the cage that's supposed to keep this square nut captive.
In my case, it was completely mangled and fell out.
OK now that you can see and have some access to the nut, It's time to pull out your welder. This part is exceptionally difficult because you have to weld directly upwards against gravity, and you want to make sure you get the wire all the way up in the hole and not stuck on the sides of your new access panel. I would recommend starting by making contact with the captive nut first and trying to get the flow onto the inside of the subframe as gravity pulls it down.
Here are my crude welds
Once you have a secure weld on the nut, you should be able to carefully crank out the bolt. Just be aware of the secureness of your welds as you crank on it as you don't want to break them.
Now you can continue doing whatever it is you set out to do.
For me it was replacing the control arm.
I hope this post has been helpful and keeps someone from completely scrapping their car. That being said, If you do have this issue, I would strongly recommend looking into a new subframe lol.
2010 Toyota Yaris 3dr HB 5spd
2004 BMW X5 4.4
1995 BMW 530i
1989 BMW 325E
E34_Guy is offline   Reply With Quote
Old 05-10-2022, 06:03 PM   #2
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150
This is why undercoating with quality undercoat is a worthwhile investment.
My Yaris is 8 years old and looks fantastic underneath.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 05-11-2022, 01:51 PM   #3
E34_Guy
I completely agree. I don't think most Canadians who bought these cars 12 plus years ago cared enough to do that
2004 BMW X5 4.4
1995 BMW 530i
1989 BMW 325E
Old 05-19-2022, 06:54 PM   #4
xdarkxfirex
Drives: 2015 yaris le
I just did mine two days ago. Barely took two rattlecans. I used thick stuff similar to rust check coat and protect but it was branded by emzone. $5 a can at my local parts store.
I have 4L of coat and protect at home and a gun but I didn't want to ask my neighbor to use his compressor
xdarkxfirex is offline   Reply With Quote
Old 05-27-2022, 08:21 PM   #5
CrimsonEclipse
Drives: .
I had the exact problem.
Had to replace the cross member.
CrimsonEclipse is offline   Reply With Quote
Old 06-03-2022, 07:14 PM   #6
sh0rtlife
my wifes 07 has ZERO undercoating and ZERO rust...victoria is where it spent the first half of its life, second half here in oregon
but its also why im studying you guys who have the rust issues so i can pre prep the car to never rust
arm, control, rusty, spinning, subframe
Big rust hole at rear control arm shepd DIY / Maintenance / Service 26 07-12-2021 05:39 PM
Broken Control Arm Bolt Sirius-XM DIY / Maintenance / Service 4 02-29-2016 08:27 PM
Front camber bolt & Rubber bushings.. harveyjai Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 03-28-2009 06:34 PM
Do any other Toyota front seats have same bolt pattern as Yaris? ScottFern DIY / Maintenance / Service 18 07-02-2007 11:44 AM
