Old 06-15-2007, 01:07 PM   #1
nqd
Drives: 07 Yaris LB Absolute RED
Dealing With Rubbing
Hey currently i have tein s tech's with 205/45/16r tires and on hard cornerng i get some rubbing.....i love the springs but what is a good way to deal with rubbing besides different springs and smaller tires? rolling fenders?
the reason i ask is because im gonna be in an autox comp
nqd is offline   Reply With Quote
Old 06-15-2007, 01:36 PM   #2
nsmitchell
nsmitchell's Avatar
I have the exact same problem with my Megans. Mine rub at right around here.
Get YarAss in gear!
RIP - Casey Tatum
Old 06-15-2007, 01:42 PM   #3
nqd
How could you tell?? is there debris of rubber stuck on there?
Old 06-15-2007, 01:58 PM   #4
nsmitchell
nsmitchell's Avatar
Small hole rubbed there. At first I knew it was rubbing so I looked in the most obvious place, directly above the wheels and nothing, in a passing glance I noticed the oval shaped hole in the plastic and that was it. I will take a picture when I get home this evening.
Get YarAss in gear!
RIP - Casey Tatum
Old 06-15-2007, 03:31 PM   #5
some people just remove all the plastic. I went to a smaller tire size.
With Tanabe DF210 springs, I tried 205/50/16 tires on 16 x 7 SportMax wheels +38mm offset. Way too much rubbing, so I went down to 195's -- can't really tell the difference and no rubbing!
Old 06-15-2007, 04:45 PM   #6
YamilR
YamilR's Avatar
Drives: Absolutely Red Liftback
Send a message via Yahoo to YamilR
Thats crazy I have 205 40 17 with DF and no rubbing at all
YamilR is offline   Reply With Quote
Old 06-15-2007, 05:09 PM   #7
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Get some camber bolts. I have the same issue and my camber is off. Gaining some more negative camber will help fix the problem and even out tire wear
Old 06-15-2007, 05:41 PM   #8
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
I am kinda thrown off by all the rubbing going on.
I ordered my Tein Basics today and I have 205/50/15 +40 offset and I plan on running them as low as they will go. Ha, guess I better plan on getting some spacers or bolts or something, eh?
SPONSORED BY
Old 06-15-2007, 06:11 PM   #9
largeorangefont
Break'em off some.
Spacers make it worse. The rubbing described is on the outside of the wheelwell. The tire hits the fenderliner as circled in green in the picture above. It is really very minor, and sounds worse than it is.
Old 06-15-2007, 06:53 PM   #10
kimona
kimona's Avatar
Drives: 2014 White VITZ
If you don't want rubbing issues, you've got to run higher offsets. It's hard to believe, but just a couple of mm's make the difference!
Old 06-15-2007, 08:00 PM   #11
OxyG3nE
Drives: Toyota Yaris 2007
Send a message via AIM to OxyG3nE Send a message via MSN to OxyG3nE
i have 205/40 17 and it rub for more then a year now.. its not scratching the tire so i dont care.. only rubbing dont hurt ;p
OxyG3nE is offline   Reply With Quote
Old 06-15-2007, 09:09 PM   #12
nqd
Yea i really dont mind cause its not eating my tire ...but the sound makes it seem so bad
Old 06-15-2007, 09:10 PM   #13
mojoyaris
Ecurie Snoopy Lives
mojoyaris's Avatar
Drives: Jojo
I think it's the offset of the wheels that make a difference. I first ran autox with 17 x 7's and currently run with 16's. both tire widths are 215 wide but the offsets are different. Total diameter is the same.
With the coilovers people tend to want to lower them too low. It's also the spring rates you are running on the coilovers as well. Some people don't have a stiff enough spring rate and are running them low to get the tucked look. On track it doesn't work as well.
So first, check the offset. My friend has 205's (instead of 215's) on his 17x7.5 inch rims to reduce the rubbing and he lowered his car pretty darn low for that neat tucked look.
Problem is when he will go to autox he'll rub no matter what. His spring rate is not hard enough and he's running too low.
So don't run too low if you have softer spring rates.
I think if you are running with lowering progressive rate springs you shouldn't really have a problem with them. Stiffer dampeners will help for this setup.
If you have a set of coilovers with camber adjustments it's fun to dial in the camber and this will reduce the rub too., Just on the street it makes for quirkier handling.
I think ultimately for autox you'd want 15 inch rims. They're lighter and you really want to reduce the unsprung weight of the wheel which helps with braking, acceleration and traction.
Sponsors and Organizations:
Toyota Rally Canada
Yokohama Tire Canada
Western Canada Rally Association
Ecurie (Team) Snoopy Canada, racing since 1966
mojoyaris is offline   Reply With Quote
Old 06-16-2007, 01:05 AM   #14
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
I have 17 x 7 inch wheels with 38mm offset (the lowest recommended) with205/40/17 tires and NF210 springs. Absolutley zero rubbing. Maybe it's because of the smaller tires. I now wish I would have gotten the 205/45/17 for the taller sidewall, but, maybe then I would rub.
Old 06-19-2007, 03:57 PM   #15
nsmitchell
nsmitchell's Avatar
Since it is rubbing only plastic I'm not worrying about it anymore.
Get YarAss in gear!
RIP - Casey Tatum
Old 06-20-2007, 08:03 AM   #16
grampi
Drives: Corolla
Not lowering the suspension would help emmensly.
grampi is offline   Reply With Quote
Old 06-20-2007, 08:06 AM   #17
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
I had 215/40/17 and the rear rubbed then I changed to 205's and it never rubbed with the 205's and a +40mm offset.
Old 06-20-2007, 08:17 AM   #18
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
Glad to know, I havethe 205 45 17. i was planning to get 215 40 17 but u changed my mind now.
whats the difference between 205 and 215? 4got
-- Blen
new rims, some rubbing, best fix? cali yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 06-04-2007 05:26 PM
Checkout the drop! spkrman Wheels, Tires and Suspension Forum sponsored by The Tire Rack 25 05-06-2007 12:06 PM
need 17inch rim guidence chino_potato Wheels, Tires and Suspension Forum sponsored by The Tire Rack 46 04-09-2007 12:09 PM
