Old 10-16-2023, 10:40 PM   #1
rpster
Drives: '07 Yaris Liftback
NST Pulley Kit and modded 1ZZ throttle body
NST Pulleys for 1NZ-FE - Crank and Alternator. Water pump pulley SOLD Used for about 10k miles, light wear and scratches from use. Normally $210 New from NST. Asking $100 obo + shipping
Modded 1ZZ Throttle Body. Has the following mods to work in a Yaris with a 1NZ-FE, ready to drop in!:
  • 1NZ-FE control board
  • Adjusted minimum valve opening to resolve high idle
  • Custom CNC adapter plate - allows use of stock intake gasket
  • Rotated coolant ports to fit Yaris hoses
Asking $80 obo + shipping
rpster is offline   Reply With Quote
Old 11-01-2023, 06:57 AM   #2
Calrenman
Drives: 2015 Toyota Yaris LE Hatchie
Hello. Would you consider selling just the water pump Pulley?
Has the adjustment bolt for the 1ZZ been exposed? Is that how it was adjusted?
Thanks
Calrenman is offline   Reply With Quote
Old 11-01-2023, 02:00 PM   #3
rpster
I'll ask $50 for the water pump pulley
Yes, I removed the epoxy plug and had to grind a flat into the set screw to adjust the idle since it was stuck in place. After adjustment, it was sealed with SteelStik epoxy. It should be easier to remove this time with a pick.
