Old 06-15-2006, 07:14 PM   #1
David81
Question painting alloy black..
I have manufacture alloy rims from toyota... i dont' like the grey color. Does any one know if its a good ideal to paint alloy rims black?
I want to paint it black but dunno what kind of paint to use if i want to paint it my self.. Or where to take it for a paint.
Do people paint rims? I live in Scarborough Ontario.
David81 is offline   Reply With Quote
Old 06-15-2006, 10:09 PM   #2
lowkey
lowkey's Avatar
Drives: 90 Integra, 07 Yaris
You would probably want to look up...
I have painted some of my wheels before not the Yaris and it turned out pretty good. Just follow the directions on the can.
http://www.duplicolor.com/products/wheel.html
lowkey is offline   Reply With Quote
Old 06-15-2006, 10:10 PM   #3
Supa Lao
Drives: '03 Murano SL AWD
Some people paint there rims, some people get it powder coated. Powder coating it will last longer. But painting it will be cheaper. Here's a tutorial from honda-tech if you want to try painting it yourself. CLICK HERE
Coming soon: Blazing Blue liftback 5spd sometime this year hopefully
Supa Lao is offline   Reply With Quote
Old 06-15-2006, 11:23 PM   #4
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Painting wheels.. yes it can be done, but I have always perfered to powdercoat mine.
The difference is night and day, and if you use this car daily, stone/rock chips will be the death of painted wheels. Yes you can burry it under a hard clear coat, but at the end of the day, you would just be better off spending the extra money on powdercoating them.
Dont be fooled, now a days, they can match almost any color with the powder coating process.
Old 06-16-2006, 01:00 AM   #5
David81
Are there any shops that do it for u?
Old 06-16-2006, 01:32 AM   #6
David81
I need a auto shop that would do powder coating for my wheels
Old 06-16-2006, 06:47 AM   #7
punch
punch's Avatar
www.yellowpages.ca
powdercoat
chrome
wheel repair...
by the time you pay to remove the tires, from the rim, coat them, then re-mount them you might as well buy new rims..and use the stock ones for winter .
and what are you going to do, put the car on blocks while you wait for the rims to be painted??
Old 06-16-2006, 03:00 PM   #8
lowkey
lowkey's Avatar
I have heard it costs about $75-$100 per wheel for powder coating.
You are better off buying some aftermarket wheels.
Old 06-16-2006, 06:33 PM   #9
Chris07LB
Chris07LB's Avatar
It all depends on the area, shop, color, how much they are taping off, etc.
FYI, I paid $110 per wheel on my 24x10's, and they required quite a bit of taping off (4" polished lips) before coating.
Old 06-16-2006, 10:35 PM   #10
fred812
Authorized User
fred812's Avatar
Drives: 2007 5 spd Hatch White
Paint them yourself, professionally
I have painted every toyota I have and never had a problem, The new paint systems are foolproof you can buy a small air gun and rent a compressor.
The cost is in the time it takes to tape them up, I have deflated the tires, placed masking paper in the gap the reinflate a little holds the paper mask perfectly, with the new breeds of paints you can even have a run in the paint and repair it after it dries, just wet sand and hit it again. As for clear coat that just turns yellow, and makes for tough touch up you can do with a q tip when you hit a bolder! Your local paint supplier will give you all the help you need.
IMHO
Fred
fred812 is offline   Reply With Quote
Old 06-21-2006, 06:11 PM   #11
IntensePower
Drives: 350z, supra, xb, 240sx
powder coat is by far the best way to do a color change on rims. like some have mentioned you can take them to any powder coating shop. the reason why it usually cost $70 for a wheel is the labor involed in prepping the wheel.
Intensepower
480-926-8797
www.intensepower.com
IntensePower is offline   Reply With Quote
Steel vs Alloy fearturtle44 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 05-12-2006 05:50 PM
