Old 07-24-2007, 05:06 PM   #1
AlphaFox
AlphaFox's Avatar
Drives: 07' Yaris Liftback - silver
Megan front tie bar?
I was just looking around at some front strut tower bars and found this:
http://www.wesellcarparts.com/store/...idproduct=5038
Is this the same thing as a normal strut tower bar? its only $56 so Im wondering why if it is...
is it the same thing as:
http://www.wesellcarparts.com/store/...idproduct=4134
AlphaFox is offline   Reply With Quote
Old 07-24-2007, 05:09 PM   #2
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
NO, the first one is for under the car and the second goes on the top.... i got the bars for under the car the other day.....
Old 07-24-2007, 05:33 PM   #3
nqd
Drives: 07 Yaris LB Absolute RED
does megan racing have a strut tower bar yet???
v
nqd is offline   Reply With Quote
Old 07-24-2007, 07:53 PM   #4
Astroman
Modded Moderator
Astroman's Avatar
Those are the same ones I saw on ebay. The ebay ad doesn't say they are megan's, but what they shipped me sure was. I purchased the mid & rear braces for about $67 w/shipping. I held off on buying the front brace because C-ONE makes a 4-point brace.
Old 07-24-2007, 09:04 PM   #5
AlphaFox
AlphaFox's Avatar
anyone have a pic on where these go??
Old 07-24-2007, 09:35 PM   #6
nqd
http://cgi.ebay.com/ebaymotors/Toyot...spagenameZWDVW
these look the same and its a 3 peice combo set....hmmm...
no feedback on seller tho....
v
Old 07-25-2007, 12:06 AM   #7
07typeS
07typeS's Avatar
Drives: 2007 White Toyota Yaris Type S
Send a message via AIM to 07typeS
can anyone confirm that these actually make a difference?
TRD Springs w/ KYB Struts and Shocks, Custom CAI w/ K&N filter and pre filter wrap, Weapon R Header, Stock 15 inch alloys, Dezod Performance pads, Tanabe Front Strut Bar, 35% front door Tint and 20% Rear doors back Tint, De-Badged Ass, Custom painted flat black interior, Pioneer deh-p6700bt w/ IPOD hookup, Infinity components up front with custom mounted tweeter, Inifinity 6x9's out back, 1 12" kicker comp cvr........
07typeS is offline   Reply With Quote
Old 07-25-2007, 01:10 AM   #8
Astroman
Modded Moderator
Astroman's Avatar
I got them and noticed the difference right away. The times I notice it mostly is on roads like CA-29, curvy as all hell or on the freeway going around corners over 80mph. I only have the mid and rear though. They compliment many suspension upgrades. I would say go for it, the price is good. I would pass on the front brace as C-ONE and a couple other make a superior 4-pt brace (although they are horribly expensive compared to the megan)
Old 07-25-2007, 02:57 PM   #9
AlphaFox
AlphaFox's Avatar
where does this bar connect if not on top of the towers?
Old 07-25-2007, 03:16 PM   #10
Astroman
Modded Moderator
Astroman's Avatar
Hope the pics help. They are from the seller on E-bay that sells these. Although no instructions are included (at least with mine) it is pretty straight forward to install. I just backed my car up on ramps, blocked the front tires and had both of them installed in about 20 min. I had a harder time with the rear bar, but after looking at the picture a couple of times I figured it out. With the rear bar you use existing bolts that help hold up the gas tank, and for the mid they provided the hardware. Not sure on the front bar, but it looks as if you use the existing bolts. It's a quick, cheap & easy mod. Below are the pics of the bars I received. Even got stickers!
Old 07-25-2007, 03:27 PM   #11
AlphaFox
AlphaFox's Avatar
ah cool. does it help more that the front tower bar?
Old 07-25-2007, 03:36 PM   #12
Astroman
Modded Moderator
Astroman's Avatar
Not sure exactly as I didn't get the front megan bar, and I had the strut bar on before the megans. I can say I did notice the additional difference after the install along with the strut bar and 17" wheels. I haven't tried removing the strut bar to see what the megans did by themselves. If your really serious just go for the mid & rear, and skip on the front. A 4-point brace up there would do more good but it is pricey. I'm sure the front one works, but probably not as well as the 4-point setup. I wish Megan had come out with the 4-point, I would have bought that already. I just can't afford right now to shell out $280 for the C-ONE when I would rather spend that money on the TRD springs and struts.
Here is the beatrush brace:
Available at C2 for $256
Here is the C-ONE:
Also available at C2 for $308
Also beatrush has a center bar for about $44:
Last edited by Astroman; 07-25-2007 at 04:01 PM. Reason: Added 4-point brace photos
Old 07-26-2007, 12:39 AM   #13
Terrorize
Toyota Newb!!
Drives: Yaris S Sedan w/ Aero Package!
These work for the LB as well as sedan right? Mounting points the same??
Terrorize is offline   Reply With Quote
Old 07-26-2007, 09:52 AM   #14
Astroman
Modded Moderator
Astroman's Avatar
Honestly I'm not sure. I guess you could look underneath at the mounting points and maybe get an idea that way... And apparently WeSellCarParts found out from megan that megan hasn't released the tie bar, someone was ripping off their name. Not sure as I haven't called megan. But regardless, mine were made well and the welds were good.
Old 07-27-2007, 12:41 AM   #15
Terrorize
Toyota Newb!!
Yeah i didn't see these on the megan site..so i was naturally suspicious...
turns out another guy on a different thread mentioned something about megan saying that they havebn't even released this product...so its someone using their name? Not too sure...i want to clarify this before i make any purchases...
Old 07-27-2007, 10:59 AM   #16
ROCKLAND TOYOTA
TRIM HUNTER
I SAW jerkratt's yesterday and i know mine are megan as well.......
Old 07-27-2007, 11:07 AM   #17
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
would the c-one 4 point under brace fit our USDM yaris? the chasis code for the JDM yaris is NCP91 i believe and our chasis code is NCP31.
Old 07-27-2007, 11:26 AM   #18
Astroman
Modded Moderator
Astroman's Avatar
I dunno... Here is the link http://www.c2auto.com/toyotayarissuspchasc1fpb.html
c2auto was a vendor here I believe... Maybe still is. I sent a email to the site and I will post their response on this thread as soon as it is received. Does anyone know if Megan has plans for a 4-point brace?
ultra racing front strut bar installed smurf Performance Modifications 9 03-10-2007 05:58 PM
2006-2007 Yaris 4 Door Front Strut Bar AEM/DC Sport KenAEM Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 02-22-2007 11:08 AM
C-ONE Front Strut Tower Bar - Installed & Impressions (Pics to Come) bigsky2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 01-10-2007 06:53 PM
2006-2007 Yaris 4 Door Front Strut Bar AEM/DC Sport KenAEM Performance Modifications 2 10-07-2006 02:26 AM
2006-2007 Yaris 4 Door Front Strut Bar AEM/DC Sport KenAEM General Yaris / Vitz Discussion 3 08-30-2006 09:43 PM
