Old 08-31-2007, 05:29 PM   #1
btc50
Drives: 2007 Yaris Sedan
Question air filter multipart
I live and drive in a fairly dusty environment, so air filters on everything I own have to be changed fairly regularly. Access to the primary filter element is easy, but I have also noticed what appears to be a secondary or inner filter element in the air box cover. While it might be 75k to 100k miles before it gets dirty, it will eventually get dirty. I can't figure out how to get the thing out. It appears to be riveted in place with plastic rivets, or maybe it is just stuck really good. I have the stock air box on my sedan, but I have never seen any kind of a secondary filter on a car before (and I've worked on a lot of different cars). a). Is it actually a secondary air filter? b). How do you get it out? It seems like you would need to get the thing out if you ever needed to clean the MAF sensor. The book doesn't talk about the engine air cleaner at all.
btc50 is offline   Reply With Quote
Old 08-31-2007, 06:37 PM   #2
aca72
aca72's Avatar
Drives: '07 Yaris S Sedan M5
May or may not answer your questions....
http://www.yarisworld.com/forums/sho...condary+filter
aca72 is offline   Reply With Quote
Liftback Air Conditioning (Cabin) Filter info Snappy DIY / Maintenance / Service 24 10-01-2010 06:36 PM
Which Engine Air Filter to choose? YANGSTER Performance Modifications 16 09-29-2007 10:48 AM
damaging or no--cabin air filter roxy84 DIY / Maintenance / Service 3 06-29-2007 01:17 PM
Blitz air filter replacement yrsdrgn Performance Modifications 2 03-08-2007 07:25 PM
