Old 10-19-2008, 11:53 AM   #1
The Yaris Performance Primer
There's a lot of information scattered out there on the hot topic of improving the performance of our little cars. So, I will try to summarize everything into this handy thread.
Before we start, please remember that performance does not always mean raw horsepower! Although there are certainly several ways to improve the engine's output, it is wise to play to the car's strengths (low weight and great handling). So, I will explore different options in several "stages", of increasing cost and complexity, as a guideline of sorts.
Also, please always keep in mind the implications of modifying a car. One way or another, you will reduce the lifespan of the car, put more strain on stock components which may fail earlier than normal. So, follow this guide at your own risk.
STAGE 1
Simple, inexpensive mods that will increase the fun factor of your ride.
  • Lightened Pulleys - NST has a full range, but you can just start with the crank pulley. These increase the responsiveness of your engine by lowering rotational mass. On the down side, they can make driving smoothly a little more difficult, especially on manual transmissions.
  • Good Tires - This is really self-evident, tires are the only contact between your car and the road. Street-rated sport tires are a good compromise for a daily driver which sees occasional racing action. You can also at this point change your wheels, if you're really after performance, you should not go over 16", as bigger wheels are heavier, which will sap a lot of the limited power available.
  • Short Shifter - If you have a manual car, this is a must. You'll shift between gears faster, meanign less "dead time" when you are not accelerating. Three options here, NST or TRD which are installed in the engine bay, shortening the lever action on the gearbox, or TWM's which is installed in the cabin, essentially a shortened version of the stock gear stick. it makes for a nice cosmetic improvement too, but may be harder to reach.
  • Lowering Springs - Several advantages here, first it makes the car look a lot better, secondly it improves handling somewhat by limiting body roll. Quite a few choices here, Tanabe and TEIN's offerings are quite popular, but there are several others.
  • Tie Bars (aka Strut Bars) - The efficiency of the front tie bar is a disputed issue, but it is meant to strengthen your car under heavy cornering, giving more steady, controllabe handling. Rear strut bars are also available, and other underbody stiffening braces if you are feeling adventurous
  • Intake and Axle-back Exhaust. On this car, most of the aftermarket intakes and exhausts do not bring a whole lot of power to the table, and if they do, it's mainly at high RPMs. Still, they can dress up an engine bay/rear end of the car, and give a much more sporty sound to the car (which will make it feel faster too ) Many many different brands and models here! We have a few members who have run their cars on a dyno after installing these, aftermarket headers (also known as I-H-E combo), and crank pulleys, it is good for about 10-15HP gain at the wheels.
STAGE 2
More "meaty" mods that will really start to give your car more punch on the track, while remaining affordable.
  • Coilover suspension - You could just upgrade your struts to TRD ones, but if you are seriously considering competition with your car, you should go for adjustable coilovers. These will let you lower the car as much as you want, and give you control over the damping force. By altering the balance of this damping between the front and back of the car, you can fine tune the way it will react while turning (oversteer vs. understeer). Other suspension mods can be considered: camber bolts will improve the grip of your tires when in a turn.
  • Header and Cat-back exhaust - The stock midpipe of the Yaris is quite restrictive due to the catalyzers and resonator. By replacing those with high-flow versions, and using slightly larger tubing, good gains can be achieved. Micro Image carries Nitto Performance midpipes, or you can get it custom-made. As for a replacement header, DC Sports makes the most promising one. Although Megan Racing offers one too, the DC header has longer runners, which apparently improves mid-range torque. Though, AFAIK, this is yet to be proven by a dyno chart.
  • Weight Reduction - Imagine how much easier it is to push around an empty shopping cart compared to a full one. The same applies with cars, lower weight improves your acceleration, braking, and handling. You can reduce weight in two ways: Replacing existing parts with lighter ones (i.e. CF hood and rear hatch), or stripping out unneeded interior trim parts. Bucket seats are also a good option to include here, giving more support to the occupant, and lowering weight. The good thing about weight reduction is you can do as much or as little as you want. You could just remove the spare wheel, tools, and the rear seat bench, or rip out every bit of plastic from the interior.
  • Uprated Brake Pads - A bit of an optional upgrade here, since the light weight of the car does not put so much stress on the brakes, but better pads can help against fading during heavy track use. You should also optionally consider at this stage, racing brake fluid and stainless steel hose upgrades for more consistent braking.
  • Racing Clutch and Lightweight Flywheel. - An uprated clutch will be stiffer (though the stock clutch is quite mellow to start with), giving you more efficient shifts. A lightened flywheel enhances the effect of the crank pulleys, giving you an engine that will really respond.
STAGE 3
MORE POWER! At the time of writing, there are not a lot of reliable options available to us to increase the output of the engine itself. This is due mainly to an ECU that is notably hard to crack. So, a lot of the following information is still theoretical, or in prototype stages.
  • NA Tuning - increasing power without turbos or anything of the sort. This is usually done by using modified camshafts (none available), or higher compression pistons (which are available). ECU remapping is also an advantage, but currently, as mentioned, not fully feasible. There's also a high-flow intake manifold in the works that looks to give a nice increase in power at high revs.
  • Nitrous Oxide (also wrongly known as "NOS") - By far the cheapest way to get a boost in power. Due to the design of the fuel system, only a wet shot system would be feasible, but there are concerns over the possibility of the plastic intake manifold cracking under low temperature or in the even of intake blowback. We know of one member here (project y) who is running a Nitrous system, reportedly with no problems.
  • Supercharging - Using the engine's rotation to power a blower, which then forces compressed air into the engine, creating more power. Superchargers create a linear increase in power from low RPMs, though the maximum power increase may not be as much as a turbo's. Currently there are two options: Blitz's Roots-type superchager or Power Enterprises' Rotrex-based centrifugal supercharger.
  • Turbocharging - A very popular way to increase engine power, by using the force of the exhaust gases to turn a turbine, which in turn forces more air into the engine, thus increasing power. There was a company, ZPI, which has since gone out of business, which offered a kit for the Yaris. Their kit produced a safe, relatively low boost of 7psi, and they claimed a dyno result of nearly 180hp at the wheels. Currently there are several entities, such as our very own Garm Beall working on bolt-on turbo kits, but the main hurdle is once again the engine management.
  • Engine Swap - Why bother boosting an economy motor when you could change it for a bespoke sports engine? Several swaps are feasible, I've heard of 2ZZ-GEs, 3S-GE, even seen in a magazine a turbo'ed 4A-GZE in a Yaris! Or you could be blasphemous and put in a Honda engine... or just go crazy and follow the "Project Sideways" philosophy, by changing the car to rear-wheel drive with a longitudinal engine! The main drawback here is the rather limited size of the engine bay, it'll be hard to fit in a bigger engine, and maintenance of that engine may be quite cumbersome. But, in the end, it's probably the only way to create a true mini monster
STAGE 3a
Other stuff not related to the power increasers mentioned above, but which will come in useful at this stage.
  • Roll Cage - So that your car doesn't get crushed like a soda can if you get into a bad accident on a track. Can also stiffen the car, improving handling.
  • LSD - Limited Slip Differential, this is most useful when racing, as it prevents your wheels from spinning needlessly if they lose traction.
  • Uprated suspension components. - I'm not sure if anyone offers these yet, but strengthened suspension arms and polyurethane bushings would help improve handling even more.
  • Rear sway bar to stiffen rear suspension.
  • Higher performance fluids as an option. Kaaz gear oil made a huge difference in my trans feel, and better brake fluid goes with better pads, IMO.
  • A couple of gauges an essential partner with performance mods, I think the most important 2 gauges you can add are water temp and oil pressure. and of course, a TACH for goodness sake.
So there you have it! I cannot possibly claim to know absolutely everything about this car, this post is meant to be a general overview/guideline.
Old 02-11-2009, 02:43 PM   #2
RooS
RooS's Avatar
Drives: red yaris hb 2001
what can i change on my yaris i got a mk1 :D! but i cant find performance pieces for my model :<!
RooS is offline   Reply With Quote
Old 02-19-2009, 09:12 AM   #3
id3379
§†ęĄ¶‡Ћ-NCP96
id3379's Avatar
Awesome information !
for brake pad's i'd recommend HAWK pads, they are top-notch track pads :)
id3379 is offline   Reply With Quote
Old 02-19-2009, 10:20 AM   #4
botchilah
Drives: white and red shiny things
SS brake lines would also do wonders for improving feel and resisting fade. Goodridge makes them for the Yaris as well as Project U, Wedsport, Endless and APP according to my supplier here.
botchilah is offline   Reply With Quote
Old 03-10-2009, 03:38 AM   #5
1nz
Drives: Vios
any review on dme and dc sports header if possible dyno figures? im planning to remove my cat, use a 2" resonator and 2" stainless steel piping
Please visit us @:
greddyvios.blogspot.com
1nz is offline   Reply With Quote
Old 11-08-2009, 02:22 PM   #6
chongopants
Drives: 2007 Yaris Hatchback
Send a message via AIM to chongopants Send a message via MSN to chongopants
anyone have hard numbers on dynos for all the headers or even some of them? I am running a thread and having a hard time finding those figures.
chongopants is offline   Reply With Quote
Old 11-08-2009, 08:38 PM   #7
gmodder
Riceman43
Drives: 2009 Yaris 3door
Hey man.. i will have my Nitto midpipe and Dc header installed on Friday...Would be more than happy to let you take for a spin...I still need to take my backseat out though...
gmodder is offline   Reply With Quote
Old 04-04-2010, 08:35 PM   #8
largeprojo
Drives: 2008 Yaris HB
Ok, got rid of the muffler. Sounds pretty cool. Here is the issue though. Put a Spectre FIPK on and the damn thing would just not run. What am I doing wrong? Do I have to put a performance MAF sensor in or do I have to chip the thing as I can seem to find a way to re map the fuel system. Any help will be appreceiated, thanks.
largeprojo is offline   Reply With Quote
Old 05-08-2010, 01:13 AM   #9
dnys
Drives: ordinary Yaris
Hi, I have a 2007 M/T yaris, the mod that have been done for now is just Open air filter, grounding wire, and iridium spark plugs..
I'm thinking to install a quick shifter for the next step but the underdrive pulley from NST always stuck in my mind..
can please anybody tell me which one worth more?
dnys is offline   Reply With Quote
Old 06-17-2010, 11:33 AM   #10
bazb
Drives: Toyota Yaris 1.0 2006
I'd say, go for the quickshifter first. I haven't tried both, but from what I've read the pulleys only make a slight difference in responsiveness, and the short shift kit a huge diff in shifting.
How did the grounding wire and sparkplugs improve your ride?
bazb is offline   Reply With Quote
Old 06-18-2010, 11:44 AM   #11
dnys
is it possible to use 4 age cyl head on 1NZ-FE?
Old 06-18-2010, 12:19 PM   #12
no
Old 07-19-2010, 07:56 PM   #13
Astroman
Modded Moderator
Astroman's Avatar
Another worthy mention is the 1ZZ throttle body swap.
Old 10-07-2010, 04:23 PM   #14
Chaldon
Drives: 08 Yaris 3d
Thanks eTiMaGo! Best informative post on possible upgrades for my new (used 2008) Yaris.
What I'm having trouble finding is these upgrades in some sort of list/chart basted on cost along with how easy it is like in your post. I want to start modding my car with the cheapest and easiest first.
I figure I'll add in some front strut bars because they are relatively cheap. That and I hate slowing down for off-ramps with 30mph turns. If I moved to a windy area I'd add in the rear sway bar. Sport tires when the economy ones needs replacing. Maybe some of the fanboy mods like using the fog light as an extra air intake for a semi-forced air into a HP drop in air filter. There's a good thread with pics for that here in YW, btw.
Chaldon is offline   Reply With Quote
Old 12-24-2010, 12:51 PM   #15
leinadeb
leinadeb's Avatar
Drives: 2001 Toyota Vitz Rs
I've just ported and polished the cylinder head of my 2nz Vitz.. I haven't seen that much of a difference in the performance. Do i need to upgrade the injectors to have a better flow of petrol and do i need to change the throttle body?
leinadeb is offline   Reply With Quote
Old 12-25-2010, 04:33 PM   #16
crolandiz
Drives: Yaris Sedan '08
Hi, what about Iridium Spark Plugs? Let's say Denso IK-16, do you think put these sparks is good maybe for stage 1?
crolandiz is offline   Reply With Quote
Old 12-25-2010, 06:37 PM   #17
leinadeb, if you ported and polished and got no gain, you probably are restricting the airflow.
Are you monitoring your air/fuel ratio? That will tell you if you need more fuel or more air.
What intake?
Old 05-17-2011, 02:18 AM   #18
raymondcassar
I have a Yaris automatic 1300cc petrol. I would like to install a turbo kit what will be the price?
raymondcassar is offline   Reply With Quote
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 09:18 PM
Yaris Crashed! elsteverino889 General Yaris / Vitz Discussion 13 11-06-2006 02:59 AM
