Old 12-07-2008, 11:55 AM   #1
iwantayarisnyc
Drives: 08 sedan auto
Widest tires I can get for 15 stock wheelies
tire rack says 205/55/15
i've heard that wider tires means more stability on the road, and the wind won't push you around as much
is it true?
will it slow down my yaris?
thanks!
iwantayarisnyc is offline   Reply With Quote
Old 12-07-2008, 11:58 AM   #2
Split
Drives: 2008 Yaris Sedan
Exclamation
if you want to go wider on the stock 15s, i wouldn't recommend going wider than 195. you'll be stretching the tires too much.
Split is offline   Reply With Quote
Old 12-07-2008, 02:00 PM   #3
anonymous user
rarer than JDM -1 of 1!
anonymous user's Avatar
Drives: 07yaris
I'm on 195/55/15's on the same setup you are looking at. I would agree with Split that the difference b/w going 10mm wider is not as important as the safety factor of stretching tires, IMO.
I also live in a windy climate, so that was also my concern while upgrading my tires.
The gearing will change, and the tires will feel less responsive torque-wise.
But the grip should make up for it.
anonymous user is offline   Reply With Quote
Old 12-07-2008, 02:37 PM   #4
kimona
kimona's Avatar
Drives: 2014 White VITZ
You can very safely install 205mm tyres on wheels from 5.5-7.0". No worries, mate. Recommended replacement size for the Yaris is indeed 205/55/15.
BTW, stretching a tyre means attempting to install a narrow tyre on a wide wheel; for example, 195mm tyres on 8" wheels. This kind of fitment is not recommended.
Old 12-07-2008, 04:40 PM   #5
iwantayarisnyc
thanks everyone, i'll probably be getting 205/55/15 tires
Old 12-08-2008, 09:14 PM   #6
anonymous user
Drives: 07yaris
As will i probably for my next set. Update us i=on what you end up purchasing.
Can I use stock tires on these 15" rims? songa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 02-18-2009 07:11 AM
Keep tires on stock wheels? LtNoogie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 10-31-2008 10:00 PM
FS Brand New Stock rims w/ Tires FlintS Items for Sale by private party 10 09-24-2007 08:22 PM
FS: 07 yaris RS stock rims n tires thegame11 Items for Sale by private party 5 04-15-2007 01:25 PM
FS: Stock tires on steelies spkrman Items for Sale by private party 9 04-12-2007 06:45 PM
