Old 11-26-2008, 02:17 PM   #1
songa
Drives: 2009 Yaris Sedan (Black)
Can I use stock tires on these 15" rims?
i have a new 2009 yaris sedan, with the 15" steel wheel with wheel covers.
i just found the Motegi SX5 rims in silver, 15x6.5 i believe. the recomended tire size is 185/60/15. here is a link from tirerack:
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
will those fit my stock yaris tires that i have on right now? so i can just order the rims only, without tires, and have them installed somehwere using my existing tires?
also, with those rims installed, it shouldnt affect my odometer/speedometer readings at all since its the same size as the OEM steel wheels and tires, righT? so itll only affect those meters if i have bigger or smaller wheels installed?
thanks again u guys have been a huge help so far
songa is offline   Reply With Quote
Old 11-26-2008, 03:11 PM   #2
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Yes....
Your Stock wheels will fit into a 6.5" wheel with no problem.
A lot of people here have done it.
A little advise... the offset on that wheel is a little low for the Yaris. That one on your link is a +35
You could have some rubbing.
It should be ok as long if you don't plan on lowering the car on the future. Or you don't usually carry 3 grown ups in the back of your car.
For an un-lowered car the ideal offset should be 40+ or higher.
For a lowered car you should look for 42-45+ offset
Old 11-26-2008, 03:14 PM   #3
songa
Originally Posted by CASTREX View Post
Yes....
interesting...thanks. what exactly does the offset values represent, and what is rubbing?
Old 11-26-2008, 03:24 PM   #4
CASTREX
CASTREX's Avatar
Basically the offset measures how much the wheel sticks out or tucks in the fender of the car.
Go to The Tirerack.com. They have a lot of technical information regarding this subject.
Now a Yaris with an offset of 35+ like the wheels on your link will rub the outer side of the tire on the fender of the car. In other words, the tire will stick out a little too much.
This will happen over a bump or when carrying heavy load.
You want enough offset so your wheel can move freely inside the fender of the car when the suspension is compressed.
Old 11-26-2008, 03:35 PM   #5
songa
ahh isee...so the smaller the offset value, the more the wheel will be sticking out? this makes sense if its lowered as you said, since you would want a larger offset value to have the wheel tucked ina bit more and away from the fender, correct?
ok..so i should be looking for a wheel with offset of 40 or more? how about these:
so far, these seem to have all the matching specs....
also, how much do the 15" stock wheels weigh? i want to see if these 17lbers are lighter...
CASTREX: thanks again for all your help!!
Old 11-26-2008, 04:18 PM   #6
kimona
kimona's Avatar
Drives: 2014 White VITZ
15x6.5, ET35, 185/60/15, is good fitment for the Yaris. With the +35 offset and the 185mm tyre, you will have no rubbing issues whatsoever! If you plan to run OEM 185's, any wheel with ET35-45 will be fine. No worries.
Perhaps you can checkout this website as well: discounttiredirect.com
Lots of wheels $100 or less, plus free shipping.
Old 11-26-2008, 04:54 PM   #7
CASTREX
CASTREX's Avatar
I guess you are right. With the OE tires he will have no rubbing with a 35+
But will be limited in the future if he wants to upgrade to wider rubber right?
Old 11-27-2008, 02:44 AM   #8
songa
thanks guys! i dont think ill ever want to go wider anyway...i dont really want to do anything thats gong to hurt fuel economy as that is the main reason why i chose this car over many others. but that 15" setup with 35 offset sounds good with 185OEM tires.
Old 02-17-2009, 07:38 PM   #9
Tonavi
Tonavi's Avatar
Drives: 2007 Yaris HB
If I understand correctly...
I could buy some 15x6 wheels and put my stock 185/60/R15 (Potenza RE92) tires on them with no problems at all???
I hope so, as 5.5" wheels are harder to find.
Tonavi is offline   Reply With Quote
Old 02-17-2009, 08:05 PM   #10
kimona
kimona's Avatar
185/60/15 tyres will safely fit wheels from 4.5"-7.0" in width.
Old 02-18-2009, 03:52 AM   #11
phenoyz
phenoyz's Avatar
Drives: yaris
Yes....
what if your offset is 41? is it still ok
i'm planning to lower my sedan
15x7, 41 offset
phenoyz is offline   Reply With Quote
Old 02-18-2009, 07:11 AM   #12
kimona
kimona's Avatar
15x7, ET41 should work just fine.
WTB: 4 Stock 15" Steel Wheels (with or without tires) kapo Items for Sale by private party 5 04-01-2011 05:35 PM
Need Two Stock 15" Tires 185/60/15 With 70% Or More Tread The Architect Willing to Buy by private party 4 10-20-2008 09:22 PM
FS Brand New Stock rims w/ Tires FlintS Items for Sale by private party 10 09-24-2007 08:22 PM
Need help when ordering my tires and rims thomasward00 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-26-2007 09:40 PM
FS: 07 yaris RS stock rims n tires thegame11 Items for Sale by private party 5 04-15-2007 01:25 PM
