![]() Drives: Yaris Hatchback Join Date: Nov 2008
9003 Harness
So does anyone know which pin is the ground, the one for high and the one for low?
also when high beams are on, does the low beams stay on also? thanks! |
Rides canyon walls
Drives: 1988 RX7 FC 10th AE Join Date: Jun 2007
Im on my phone and trying to make a harness diagram with text so bare with me.
| _ | This is the harness assuming that youre looking at it with the middle pin at the bottom. Red = ground Blue = low beam Green = high beam I had to find this out when installing my HIDs because it had no high beams and had only 2 pins to connect to the harness.
![]() OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header |
i belive the yaris uses separate grounds and a common positive.
it should be one common ground and two positives, does the low beam have power when the high beams are on? need to rewire a HID kit, telescopic =D
i think its stupid how its one bulb for the highs and low, if it goes out then you dont have a backup on that side
thanks a lot for the diargram and help also!
Rides canyon walls
yeah thats right my bad. ground in diagram is actually a common positive.
#9 | |
| radio wire colors & alarm wire color reference guide | battleversiontc | In Car Entertainment + Electronics (audio / video / alarm) | 43 | 06-06-2023 02:12 PM |
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
| F.S. MOMO Acropolis Evo Carbon Kevlar Competition Seat with 4 piont Harness | Ric n Sov's Vitz RS | Items for Sale by private party | 2 | 10-19-2008 01:34 AM |
| Headlights harness | slvryaris | Cosmetic Modifications (Exterior/Interior) | 13 | 07-19-2007 12:19 AM |
| How exactly does an heavier duty harness work? | IsLNdbOi | Performance Modifications | 5 | 09-26-2006 04:19 AM |
