Old 10-31-2008, 06:32 PM   #1
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
stickie this radio wire colors & alarm wire color reference guide
this should be a sticky 2007-2008 might be same for 2009 not to sure
12volts yellow (25A), gray (15A) + ignition harness
Starter black (x2)(common) + ignition harness
Second Starter N/A
Ignition pink + ignition harness
Second Ignition green + ignition harness
Third Ignition N/A
Accessory white + ignition harness
Second Accessory N/A
Keysense yellow - ignition harness
Notes: Using the status output from the remote start to trigger this wire will disarm the factory alarm without unlocking the doors.
Power Lock brown - driver kick, 20 pin plug, pin 7
Notes: Meter this wire while turning the key in the driver door key cylinder.
Power Unlock yellow to green (double pulse) - driver kick, 20 pin plug, pin 8
Can also use the passenger door key cylinder unlock wire, which only requires a single pulse. It is green (-) at the fuse box, middle, 18 pin plug, pin 15.
Lock Motor white to orange 5wi driver kick, 20 pin plug, pin 10
Unlock Motor lt. blue to pink 5wi driver kick, 20 pin plug, pin 20
Parking Lights+ green + fuse box, top L, 30 pin plug, pin 29
Parking Lights- white - headlight switch
Notes: Not available on all models.
Hazards black - hazard light switch
Turn Signal(L) lt. green + fuse box, top L, 30 pin plug, pin 27
Turn Signal(R) yellow + fuse box, top L, 30 pin plug, pin 28
Reverse Light red + fuse box, top L, 30 pin plug, pin 30
Door Trigger see notes - fuse box, top left, 30 pin plug
Notes: The LF door is red in pin 21. The RF door is blue in pin 24. The LR door is green or yellow in pin 5. The RR door is blue in pin 20. The rear doors are common on some models. Use all four wires and diode isolate each.
Dome Supervision pink - fuse box, L side, 6 pin plug, pin 2
Trunk/Hatch Pin lt. blue - fuse box, top L, 30 pin plug, pin 7
Hood Pin white - pin sw or theft warning ECU, pin 4
Notes: The theft warning ECU is behind the glovebox.
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Tachometer lt. green ac data link conn. under dash, pin 9
Wait to start N/A
Brake Wire green to purple + fuse box, top L, 30 pin plug, pin 12
Parking Brake yellow - fuse box, top R, 16 pin plug, pin 2
Horn Trigger black to lt. green - fuse box, top, 36 pin plug, pin 28
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Optional on the sedans and S sedans, not standard equipment.
Headlight lt. blue - headlight switch
Speed Sense purple fuse box, top, 36 pin plug, pin 26
Wipers blue (L), yellow (H) + windshield wiper switch
LF Window up/dn red - green A driver window switch in door
RF Window up/dn white - pink A driver kick, 18 pin plg, pins 11, 10
LR Window up/dn yellow - black A driver kick, 18 pin plug, pins 8, 9
RR Window up/dn red - green A driver kick, 18 pin plg, pins 17, 18
Radio 12v blue + radio harness
Radio Ground white/black - radio harness
Radio Ignition gray + radio harness
Radio Illumination green + radio harness
Factory Amp Turn-on N/A
Power Antenna black + radio harness
LF Speaker +/- pink - purple +,- radio harness
RF Speaker +/- gray - yellow +,- radio harness
LR Speaker +/- black - yellow +,- radio harness
RR Speaker +/- red - white +,- radio harness
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 10-31-2008, 11:06 PM   #2
sportin83
Drives: 2008 blazing blue yaris LB
great info. this should be stickied
http://cardomain.com/ride/3151056
mods: custom sub box, i hit 141.4 db, new speakers, double-din nav, foglights, cruise, CAI, strut brace, under car braces, short antenna, remote start, alarm, actuators in doors and hatch
coming soon: window tint, custom sub grills, tach and........
sportin83 is offline   Reply With Quote
Old 11-01-2008, 12:27 AM   #3
battleversiontc
yup hopefully they do
Old 11-06-2008, 12:59 AM   #4
battleversiontc
bump
Old 11-06-2008, 06:12 AM   #5
drbilal
drbilal's Avatar
Drives: BELTA SEDAN
thanks, great info
drbilal is offline   Reply With Quote
Old 11-07-2008, 06:59 PM   #6
battleversiontc
sweet they stickied it
Old 11-07-2008, 08:00 PM   #7
sportin83
thanks for making it sticky
Old 04-08-2009, 06:43 PM   #8
dccurrent
Drives: Yaris 5 door Liftback
Just letting people know that when I opened my two front doors on the 2009 4dr liftback, the left door speaker wire was described correctly but the right door had a blue wire, not a yellow. The other wire was indeed gray, however.
dccurrent is offline   Reply With Quote
Old 04-14-2009, 02:16 PM   #9
dccurrent
Ok I just opened up my LR door and the wires are red and white, not black and yellow. This is for the speaker wires.
Old 05-07-2009, 04:30 AM   #10
battleversiontc
well if you find anything else different in the 09 please post as the wires i have are from 07-08 wasnt to sure on the 09 at the time i posted it
Old 10-12-2009, 02:32 PM   #11
spiterod
Drives: 2008 Yaris Hatchback
08 Yaris Front right speaker wires
My 08 Yaris Liftback has gray and blue speakers in the right front, not gray and yellow as all the diagrams I have seen had. I'm hoping the gray was still positive.
spiterod is offline   Reply With Quote
Old 05-03-2010, 02:19 PM   #12
Chicho
Drives: 2007 Yaris Hatchback
"Speed Sense purple fuse box, top, 36 pin plug, pin 26" Where exactly is it located?
Im a noob and need to find the speed signal for my navigation unit.
Chicho is offline   Reply With Quote
Old 05-03-2010, 03:42 PM   #13
Remove the small storage bin that is just above the hood release to get to the under dash fuse panel area.
It's pin 26 on Connector 4B in this image:
Old 05-15-2010, 12:36 AM   #14
devilgod666
Drives: yaris
need help need to get help with my 2008 yaris fatory alarm i need to find the wires plz if you can hellp me as soon as posible plz do i need it fast and if you can hellp me post the piture's where the wire's are okey cool :D:D
devilgod666 is offline   Reply With Quote
Old 07-06-2010, 06:16 AM   #15
Falconeer
Bayou Blue Pearl.
Drives: Yaris 5D Liftback Full Options
OH THANK YOU SOOOO MUCH for this! Thanks!
BOSCH 8000k HID Headlights, BOSCH 8000k HID Fog Lights. BOSCH Horn. 30% tint all round. 70% Tint mirror-finish tint on front wind shield. TRD Leather Shift Knob, Leather Steering Wheel, TRD Emblem. Height adjustable driver's seat is cool! and... That great armrest from ebay
Falconeer is offline   Reply With Quote
Old 07-17-2010, 09:35 PM   #16
toy_toronto
always toyin'
toy_toronto's Avatar
Drives: 2010 5-Dr
I just upgraded my RR and LR stock speakers with a pair of Pioneer 6.5" (TS-A1673R) on my 2010 5-dr hatchback.
The factory wiring colors were:
L Rear Speaker: red (+), white (-)
R Rear Speaker: red (+), white (-)
-toy
Old 08-16-2010, 05:49 PM   #17
ali077
TRD TURBO
Drives: TRD VITZ TURBO 2003
any1 can help me to find speed sensor wire for a vitz trd turbo 2003?
ali077 is offline   Reply With Quote
Old 08-16-2010, 06:22 PM   #18
It's the white wire in pin 8 of the 18 pin connector to the speedometer.
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 02:02 AM
Factory wire harness or plastic aftermarket piece for aftermarket radio????? Yarisguy13 Great Lakes 1 09-17-2007 10:14 AM
Keyless Entry Wire Colors? Kaeon In Car Entertainment + Electronics (audio / video / alarm) 0 09-16-2007 02:39 PM
Radio Wire Diagram????? Yarisguy13 General Yaris / Vitz Discussion 1 04-18-2007 10:58 PM
