Old 12-21-2008, 10:46 PM   #1
Masteraal
Masteraal's Avatar
Drives: Black Yaris YRS 3dr Manual
URGENT help needed :( -DIY springs
Im just doing my springs ive managed to do the rears... after a while
but i just need help with the fronts.
the part in question is:
Next, pry up the rubber dust cap.
Under the cap is a nut holding the top of the strut assy., to the shock tower of car. Get your 17mm box wrench and loosen the nut while HOLDING the center from spinning, with a 6mm allen key.
Once loose, remove enitre assy., from car.
how do i remove that bolt? i cant seem to get a spanner ot a wrench in that small space?
is there a trick to doing it?
P.S. I havent done this part :
We need to remove the (2) Sway Bar end links, (2) Strut bolts, and (1) Brake bolt.
Follow the bolts with sizes marked, and remove.. any order is fine.
yet cos i was concerned i wont be able to remove the wiper section and that bolt.
any help would be appreciated
Masteraal is offline   Reply With Quote
Old 12-21-2008, 10:55 PM   #2
ztrack157
Vroom Vroom Beep Beep
ztrack157's Avatar
Drives: Powered Roller Skate
Send a message via AIM to ztrack157 Send a message via MSN to ztrack157 Send a message via Yahoo to ztrack157
I used offset wrenches and it worked fine. Also you can take the whole wiper assembly off for easy of access.
ztrack157 is offline   Reply With Quote
Old 12-21-2008, 10:56 PM   #3
ztrack157
ztrack157's Avatar
The wiper section is remarkably easy to remove
Old 12-21-2008, 11:16 PM   #4
Masteraal
Masteraal's Avatar
ok will do that then! :D thanks for the help :)
Old 12-22-2008, 12:42 AM   #5
Phaeton
Phaeton's Avatar
Drives: Blazing Blue Liftback
good luck getting all the plastic puzzle pieces put back together lol.
You need a hex key and an offset wrench. Getting the nut off of the strut is a pain in the ass even with the right tools.
Old 12-22-2008, 12:48 AM   #6
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
I pass on to everyone the Holy Grail of suspension installs done by none other then the one they call " chris07lb "
http://www.yarisworld.com/forums/showthread.php?t=1096
slvryaris is offline   Reply With Quote
Old 12-22-2008, 02:25 AM   #7
Masteraal
Masteraal's Avatar
yea ive got that printed out in the car while i was doing it.
I drove around looking for the offset wrench :( no one has one! its ridiculous :( i dont know what to do. i want to remove the wiper assembly but there are like 1million bolts and i have no idea which ones to remove.
does anyone know which ones to take off?
Old 12-22-2008, 12:52 AM   #8
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
I bought my offset wrench at Sears....got the nice professional one for $19....figure if I do anyone elses springs and they buy beer and pizza I made out even.
Old 12-22-2008, 03:40 AM   #9
Masteraal
Masteraal's Avatar
Yaris Manual - Wiper Washer section WW-11
is that it?
Old 12-22-2008, 05:17 AM   #10
slvryaris
slvryaris's Avatar
Follow Chris's DIY down to the last period. I followed it and me and a buddy had it done in less then 2 hrs and that includes us sitting around shootin the breeze.
Old 12-22-2008, 05:49 AM   #11
Masteraal
Masteraal's Avatar
i managed to score myself a spanner that works. is undoing that bolt supposed to be hard or does it just pop off easily?
Old 12-22-2008, 10:16 AM   #12
train317
Train317
train317's Avatar
Drives: 2008 Toyota Yaris S Sedan
Sears was the only place close I found a 17mm x 19mm offset box wrench. No wiper motor removel required. The wrench costs only $16 dollars and made all the difference in the world. Maybe I should start a "traveling wrench club" that is, keep mailing the same wrench around the country to different owners..would probably only cost a few bucks to ship! Would be interesting to see how many people could use the same wrench in a year!!!!
train317 is offline   Reply With Quote
Old 12-22-2008, 12:27 PM   #13
auxmike
auxmike's Avatar
Would a TRD strut and spring set eliminate the need to cut bumpstops?
Also, is a front end alignment be required after?
THX!
Old 12-22-2008, 02:14 PM   #14
slvryaris
slvryaris's Avatar
I would definitely do the alignment after you lower it. When I done mine it felt like it was fine but then a couple thousand miles later I had it checked and it was out of alignment pretty bad and it didnt even feel like it. So ya I would have it alignment. My local Big O done it in like 10 minutes.
With the nut on top of the strut I have seen people do it without taking the wiper cowl off. I think its just easier for some with the cowl off. Just make sure you hold the allen screw down while taking the nut off, and follow the instructions on chris07lb's DIY.
The bump stops is a topic that has many different opinions. The bump stops are there to keep the system from bottoming out. Its like if you lowered the car an inch that means you are an inch closer to hitting the bump stop so then I would cut the bump stop and inch. Two inches then I would cut it 2 inches. It just gives the whole assembly that much more room to travel without bottoming out.
Old 12-22-2008, 03:08 PM   #15
Chupacabra
Drives: 2009 Yaris liftback
You HAVE to have an offset wrench to do it RIGHT.
Chupacabra is offline   Reply With Quote
Old 12-22-2008, 03:15 PM   #16
auxmike
auxmike's Avatar
Can anyone tell or post a pic of an offset wrench please?
Old 12-22-2008, 04:25 PM   #17
slvryaris
slvryaris's Avatar
http://alloy-artifacts.com/Photos/to..._w400_h211.jpg
here ya go
Old 12-22-2008, 05:06 PM   #18
auxmike
auxmike's Avatar
Thanks!
Yeah, might be a kinda oddball item to find. We have a nice SEARS hardware store by me that sells all the wrenches and sockets alacarte. I was even able to find a 5.5mm socket to drop a Saturn steering column there!
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 09:37 AM
anyone have DIY install inst for lowering springs swapout??? Stargate YARlantIS General Yaris / Vitz Discussion 1 10-20-2008 04:18 PM
urgent info needed..(before going shopping) seanele Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 07-02-2007 11:07 PM
burnt out sub question urgent replies needed please Sway84 In Car Entertainment + Electronics (audio / video / alarm) 8 06-10-2007 08:31 PM
New Updated DIY Manual needed already?! vodkalush DIY / Maintenance / Service 4 04-03-2007 02:26 PM
