Old 07-02-2007, 03:45 AM   #1
seanele
seanele's Avatar
Drives: '07 Blazing Blue LB, '09 Jetta
urgent info needed..(before going shopping)
first of all,
i already pick Tanabe DF210 for the suspension, will get it this Thursday and hopefully installed same day.
Then,
the rims/tires..I will buy them the next day.
now the question is,
which set below that will rub,
17x7 rims and 205-40-17..?
or
17x7 rims and 215-40-17..?
or
16x8, 6x7 rims and 215-40-16..?
basically,
i want to lower the car and put a nice 16 or 17 rims with wider tires. (215 maybe?)
my wife approved the funds...so it's my best chance to dress up the baby
please help,....really need this info.
current: '07 Yaris LB - '09 VW Jetta
ex: '06 Beetle S(19x8.5 Audi A8) - MK4 GLi BMP(18x8 OZ, K04) - '03 GTi(17x7.5 Ronal, APR93) - '01 GLS - '88 GTi - '86 GTi - '83 GTi
seanele is offline   Reply With Quote
Old 07-02-2007, 03:59 AM   #2
Vanderkitten
Vanderkitten's Avatar
Drives: 2007 Yaris Hatchback
215's on 17's may rub after the springs settle. It shouldn't be bad, probably on the roughest of roads or hardest cornering on the plastic wheel well liner. Look for a 38mm offset in the 17s, I believe that's the magic number.
I personally like 17's... here are our cars with MB Weapon 17's with 205/45/17's and Megan Racing Coilovers.
Dave V- Creator-Vanderkitten- Clothing for Women Who Kick Ass!
Many thanks to our sponsors:
Weapon-R http://weapon-r.com
Megan Racing http://www.meganracing.com
Les Schwab Tires http://www.lesschwab.com
317 graphics http://www.317graphics.com
Vanderkitten is offline   Reply With Quote
Old 07-02-2007, 04:10 AM   #3
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
I had 215/40/17 on my sedan and it rubbed in the rear, but I dont know how the harchbacks are. The rims were 17x7 with a 40 mm offset.
Old 07-02-2007, 04:55 AM   #4
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
lets just say this
Mine has Tanabe DF springs + 17" wheels with 205/40/17 tyres.....perfect in my end
Old 07-02-2007, 05:31 AM   #5
YamilR
YamilR's Avatar
Drives: Absolutely Red Liftback
Send a message via Yahoo to YamilR
Originally Posted by hasher22 View Post
lets just say this
Same here
YamilR is offline   Reply With Quote
Old 07-02-2007, 08:10 AM   #6
Razr
YRS WHOR
Razr's Avatar
Drives: White 2007 Yaris E-Limited 5dr
According to the Thai Yaris freaks. 215/40R17's won't rub at all with lowered suspension. I have 215/45R17's and they have rubbed twice - both times in the front only, at speed (140+ KM/hr), on hella bumps, and with a 2" drop courtesy of a few hundred kilos of load. Only minor rubs in any case, so I'll be using the same fitment when I go low.
Note however that every brand of tire is slightly different - some 215/45R17's won't rub, others might have serious problems. I'm running Dunlop SP 9000 Sport for reference.
Razr is offline   Reply With Quote
Old 07-02-2007, 08:18 AM   #7
kimona
kimona's Avatar
Drives: 2014 White VITZ
RIMS: You can run 16x7's or 17x7's. I wouldn't advise rims any wider for most Yaris applications.
OFFSET: The Yaris is quite sensitive to offset. I recommend no less than 40mm to avoid problems; however 42-45mm would be better.
TIRES: Don't run wider than 205 rubber to avoid rubbing problems.
Old 07-02-2007, 08:36 AM   #8
I'm running 215 tires, suspension lowered roughly 1.5", and I get infrequent rubbing (only front outside wheel when braking into a curve, and hitting a bump or other uneven surface).
For you, I'd recommend sticking with the 215/40s, they seem the best combination for a 17" wheel.
Old 07-02-2007, 10:06 PM   #9
seanele
seanele's Avatar
demm...thats nice.
Old 07-02-2007, 10:07 PM   #10
seanele
seanele's Avatar
lets just say this
no rubbing??
burnt out sub question urgent replies needed please Sway84 In Car Entertainment + Electronics (audio / video / alarm) 8 06-10-2007 07:31 PM
bi-xenon info Adriaan Cosmetic Modifications (Exterior/Interior) 0 02-05-2007 06:21 PM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 10:58 PM
