Old 12-19-2008, 01:47 PM   #1
Midon
Mod Freak
Drives: 88 MR2 GT
How much to lower
I want to lower my 08 LB but i still want a nice ride quality out of it. I want it a little firmer then stock but not by much and i don't want to drop the car to the ground just a subtle drop will be good. My problem is I am not sure what to get there are many options out there. So to all you guy's that do a lot of suspension work help me out please. I need help with springs and struts. What would be best for what I am trying to do. I also would like my struts to be adjustable for when i take the yaris out to autocross. I don't want coil over's for 2 reasons. 1 too expensive, and 2 I don't need to adjust everything just the damping rate is all.
Thanks
Midon is offline   Reply With Quote
Old 12-19-2008, 01:51 PM   #2
songa
Drives: 2009 Yaris Sedan (Black)
i dont know much about autocross, but for normal every day use, with a subtle drop while still being able to use stock suspension, i think the most common choices among yaris owners are the tanabe NF210s, or the TRD springs (which i believe are often the same as eibachs). i think the NF210's will give u the smallest drop (~1.2 inches all around on avg?), and the TRD's should give about 1.2-1.5" drop i believe...hope that helps
songa is offline   Reply With Quote
Old 12-19-2008, 02:04 PM   #3
Midon
Mod Freak
Drives: 88 MR2 GT
Yea that's about what i want is 1-1.5 in drop but what about spring rate on the tanabe are they harder then stock, about the same or softer, also what struts would work well with them.
Old 12-19-2008, 02:44 PM   #4
NF's are a mere 5% firmer than stock...so pretty soft
and i could be mistaken...the only way to get an adjustable shock is on a coilover...
not sure you'd want to auto-x on nf's though.....similar enough firmess to stock and minimal drop....youre better off running in a stock class (w/o the points for springs)
Old 12-19-2008, 09:30 PM   #5
UKblackyari
Drives: yaris
I’ve been doing a bit of research in to some now shocks/struts and springs for my yaris and from what i have found (i may be wrong) but there are not height adjustable/dampening adjustable shocks/struts for the yaris outside of coil over’s. What i decided to go with is TRD shocks/struts with tein s-tech springs simply because i didn’t think i would be satisfied with the drop that the TRD springs would give me. If you want to go with coil over’s, I think Megan racing offer a well priced high and dampening adjustable package
UKblackyari is offline   Reply With Quote
Old 12-20-2008, 10:41 AM   #6
Midon
Mod Freak
Drives: 88 MR2 GT
well I know they make shocks that are adjustable I have bought them before for my 88 MR2. the shocks were only adjustable within 5 setting on there dampening. I believe they were toikoyo or something and were white. they were really nice shocks. but they don't make them for the yaris. But I may just have to get coil over since I do want to make adjustments to the dampening, and driving autocross on stock springs is a no go for me I just cant bring my self to do that.
Old 12-20-2008, 11:09 AM   #7
anubisx99
here again..
anubisx99's Avatar
Drives: 2008 toyota yaris LB
well if it helps, I have the TRD ones and as far as the stiffness is awesome, I don't know % wise but I feel like I didn't lost anything from the original ride... hope it help.
Don't be threating me with a good time!!!
anubisx99 is offline   Reply With Quote
Old 12-22-2008, 12:38 PM   #8
MUSKOKA800
MUSKOKA800's Avatar
I'm not aware of any adjustable strut/shock set-ups for the Yaris with the exception of the high-$ coil-overs. That said, now the Tokico have entered the fray with their Blues perhaps they'll expand the line to include some of their adjustable models.
Sadly, Koni's website lists nothing for any Toyota (which I find strange).
Old 12-22-2008, 12:43 PM   #9
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
I really like NF210s
Made my car look so cool and the drive is awesome! Mild drop and just a touch stiffer than OEM, feels like a new/better car!
CLA 250, 4MATIC
Old 12-22-2008, 02:19 PM   #10
Not for the Yaris. Tokico is working on Reds which will be adjustable, but they are not available on the market at this time.
Old 12-22-2008, 07:47 PM   #11
Midon
Mod Freak
Drives: 88 MR2 GT
you will have to let me know when they do. I will hold off until they are available.
DIY- rattle from lower windshield fix. PetersRedYaris DIY / Maintenance / Service 3 08-21-2011 01:29 AM
I need a lower seat! Snyprwlf47 Cosmetic Modifications (Exterior/Interior) 2 12-11-2008 10:26 PM
want 2 lower with tein but have tyre rub HELP! MR. CANTON Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 09-24-2007 05:16 PM
What parts do I need to lower a Yaris? tacsnier Cosmetic Modifications (Exterior/Interior) 15 06-18-2007 09:15 PM
