#1 |
want 2 lower with tein but have tyre rub HELP!
hey guys i have a problem, i bought 17" rims but the offset is for front wheel drive right. it doesnt touch when i turn the steering wheel or anything the only problem is when i put ppl in my back seat and wit the weight of the music if i go over any humps or dips in the road the tyre rubs on the fender lip, i would like to lower my car with tein s tech or L TECH springs if i can find them for the sedan BUT i wanted to know from anyone with a little more experience if the springs would be stiff enough with the 1.9" drop to not rub at all with the stiffer suspension?
USING 215/40/17 btw but ill have to put broader tires later on to fit the rim properly and i dont want to grind my fenders any advice would be appreciated thanks
#3 |
I have the same problem dude I'm running 205/45R17, what's the offset on your wheels? (I'm running 38 offset)
I thought of changing my tires to 205/40's but I'm just going to grinding the fenders and see.. |
#4 |
Drives: 2014 White VITZ Join Date: May 2007
Curious what the offset of those wheels are. They certainly don't look right!
#5 |
![]() ![]() ![]() ![]() ![]() Drives: 2005 Scion xB Join Date: Nov 2006
I'm quite certain that tire size is not your problem and that your rim offset is. Remember, the lower the offset, the wider the wheels will stick out. 38mm is the lowest offset you should use. From the pictures, yours look to be lower than 38. Hence, the fender rubbing.
| which spring is better..Tein or Tanabe DF? | seanele | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 37 | 08-09-2007 01:35 AM |
| Tein S-tech for Xb 04+ on Yaris Hb 2005 | Fer.pa | Central and South America | 18 | 08-04-2007 10:59 PM |
| TEIN - Basic Coilovers *Now Available* | EnduroMTS | Sponsors Classifieds Area | 4 | 10-13-2006 02:43 PM |
| TEIN Basic coilovers | C2AUTOSPL | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 06-26-2006 01:57 AM |
