Old 12-23-2008, 01:06 PM   #1
bikegerm
bikegerm's Avatar
Drives: 2007 Meteor LB
TRD Rear Sway Bar Install ??
So I've got a TRD rear sway bar coming next week. When I installed my Tanabe front strut brace I was instructed to raise the wheels off the ground when installing and adjusting the tension on my brace. Do I need to do anything like this when installing the rear strut brace or can I just drive the rear end up on my ramps and bolt it on?
Happy Holidays Everyone !! I hope everybody gets all the "mods" they asked Santa for !! Ho.. Ho.. Ho.. !!
Randy LeRoy
www.airshowmastering.com
randy@airshowmastering.com
bikegerm is offline   Reply With Quote
Old 12-23-2008, 03:01 PM   #2
andries
aka Jack Wolfskin
Drives: Yaris
Send a message via MSN to andries
You must jack up the car so the tension is off the shock bolts.( to pushing them back as the nut is off) Then fit the sway bar.
10 min. work (with two people 5 min.) and then you have a very great mod. Your car will be a lot better handling.
good luck
andries is offline   Reply With Quote
Old 12-23-2008, 03:17 PM   #3
good luck
Jacking is not necessary. I put two on with the cars sitting naturally. Shock mount bolts slide easily even with the vehicle weight on them. If you a small enough to worm your way under the car without jacking or ramps, then you are good to go.
Old 12-25-2008, 06:04 PM   #4
bikegerm
bikegerm's Avatar
align?
Will I need a rear end alignment after I loosen those bolts and attach the sway bar?
Merry Christmas !!
Randy LeRoy
Old 12-25-2008, 06:38 PM   #5
No, an alignment is not required.
Old 12-26-2008, 01:20 AM   #6
YarisSedan
Drives: 08 Yaris Sedan
Uh there is no alignment points in the rear nor can the alignment go out.
Old 12-26-2008, 02:46 AM   #7
uncleyaris
Great job BTW!!!!
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-06-2008 12:37 AM
Difference b/w TRD Rear Sway Bar and these? IsLNdbOi Performance Modifications 8 11-11-2008 10:13 PM
DIY - TRD rear sway bar kurokoma-kun DIY / Maintenance / Service 0 10-20-2008 02:21 PM
Best place to purchase a Tanabe strut bar and or TRD Rear anti sway bar? thomasward00 General Yaris / Vitz Discussion 3 07-12-2007 02:22 AM
TRD rear sway bar chrisada_to2a Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 05-13-2007 05:43 PM
