Old 05-19-2009, 11:52 AM   #1
detroiter
detroiter's Avatar
HELP...I'm changing the springs/shocks...where to jack up?
I'm going to be getting to this long awaited project and I'm curious where the best place is to jack up on the front and rear ends when doing each side. Also, on all of the DIY guides, I don't see anything about how to get the rear shocks off...is it just held on by the two bolts in the hatch area where you pop the plastic top off?
One other question is when using the box wrench to get the top off of the front struts, do I take those all the way off or will the spring fly underneath? I know it's kind of a dumb question but want to cover all of my bases. I'd imagine you have to take the bolts off of that top hat area under the hood so you can actually get the strut top hat off, but just not sure.
Old 05-19-2009, 12:00 PM   #2
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
http://www.yarisworld.com/forums/sea...earchid=550728
and i'd recommend removing your wiper tray to access the top bolts.
the top bolts only hold the struts in place. there's another bolt underneath that holds the spring perch on.
an impact gun will make your life SO much easier if you have access to one.
Originally Posted by xnamerxx
you nailed it sir.
Old 05-19-2009, 12:48 PM   #3
detroiter
detroiter's Avatar
the link you gave me has no results found.
thanks for the heads up on the bolts, i feel better knowing the spring isn;t going to fly off and damage me by undoing the top hat bolts in the engine bay.
Old 05-19-2009, 01:45 PM   #4
IllusionX
Drives: 07 Yaris Sedan Aero
use standard jack points.
Old 05-19-2009, 01:49 PM   #5
detroiter
detroiter's Avatar
One other question I have is since I'm using Tokico shocks with this spring install, there's no need to cut the bumpstop right? From my understanding, I would need to cut it if I was using the stock shocks/struts but since I'm not using those and I'm using the Tokicos, there would be no need to.
Old 05-19-2009, 10:07 PM   #6
detroiter
detroiter's Avatar
Really, come on now...I can use the help.
Old 05-19-2009, 10:14 PM   #7
Tamago
Tamago's Avatar
Drives: ZZW30
did the aftermarket struts come with their own bump stops?
you nailed it sir.
Old 05-19-2009, 10:33 PM   #8
detroiter
detroiter's Avatar
no they didn't. i'm guessing i'm supposed to use the factory stops, but i'm thinking not supposed to cut them since the new tokicos are stiffer, so no need to cut in the first place.
Old 05-19-2009, 10:51 PM   #9
Tamago
Tamago's Avatar
Drives: ZZW30
the stiffness of the shock has nothing to do with the cut dimension of the bumpstop.
if you're lowering 2"
cut off 2" of bumpstop.
you nailed it sir.
Old 05-19-2009, 11:13 PM   #10
detroiter
detroiter's Avatar
so if the shock is stiffer, then what would be the sense of cutting the bumpstop? It's kind of contradicting to cut something that stops travel of the shock, yet the shock it's on is stiff enough that it wouldn't need to be done. I'm just trying to understand is all.
Old 05-19-2009, 11:25 PM   #11
Tamago
Tamago's Avatar
Drives: ZZW30
because the shock does not support the vehicle.
the spring does.
if your spring drops the car 2" you'd want to remove 2" of bumpstop so you don't bounce off the bumpstop itself except for extreme conditions. this allows your new stiffer shocks to actually do their job.
you nailed it sir.
Old 05-20-2009, 12:21 AM   #12
auxmike
auxmike's Avatar
I heard if you buy the TRD springs/shocks you don't need to cut the bumpstops.....
Old 05-20-2009, 12:25 AM   #13
808_Yaris
Where is Oahu?
808_Yaris's Avatar
Drives: 5-door meteorite metallic
i think it's because if you buy the trd springs/shocks together, so it should be fine? that's what i would think..someone please clarify for me.
808_Yaris is offline   Reply With Quote
Old 05-20-2009, 12:26 AM   #14
Tamago
Tamago's Avatar
Drives: ZZW30
....but what would it hurt to take off an inch?
is it THAT big of a deal?
you nailed it sir.
Old 05-20-2009, 01:59 AM   #15
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
For warranty purposes , yes it is , Toyota does not recomend cutting
bump stops with it's TRD products . But other after market shocks and spring
set ups it may require this to be done , as you stated ,for you to get the
best preformance/handling from them.
Old 05-20-2009, 07:46 AM   #16
detroiter
detroiter's Avatar
That's why I'm in a tangle. The tokicos are for "lowered" applications and comparable to the TRD shocks, I thought when pairing up the "upgraded" shocks/struts like these with lowering springs, nothing needs to be cut. only with the stock shocks/springs because of how soft they are compared to the trd/tokicos.
I'm getting ready right now to go outside and install the springs and shocks! Wish me luck guys, I'll need it lol. Also, the spring settling period..is it based more on how much you drive or by time? I drive alot so I need to know if they will settle sooner because of that so that I don't wait too long to get the alignment. Or do they take time to settle no matter how much you drive?
Old 05-20-2009, 09:13 AM   #17
33OH
Drives: '08 Yaris
A good rule is about 2 weeks of settling. If you drive alot, then you'll be fine with 2 weeks.
Old 05-20-2009, 10:20 AM   #18
detroiter
detroiter's Avatar
these front struts f'ing blow. having a bitch time getting off one side's top strut bolt. F'k you bolt!
Rear point jack issue bikegerm General Yaris / Vitz Discussion 11 09-25-2024 03:55 AM
Reinforce Jack points? Morgan DIY / Maintenance / Service 41 11-10-2015 07:31 AM
DIY: Aux Input Jack Adapter TinyGiant DIY / Maintenance / Service 11 11-10-2012 06:33 AM
DIY Aux Jack Install Dave DIY / Maintenance / Service 11 02-17-2010 11:15 PM
Coud someone post pictures of the jack points on the Sedan & Hatch voodoo22 DIY / Maintenance / Service 4 11-08-2008 09:24 AM
