Old 02-24-2009, 03:04 PM   #1
bikegerm
bikegerm's Avatar
Drives: 2007 Meteor LB
Rear point jack issue
Hey guys and gals. So I have a couple of 2.5 ton Craftsman floor jacks that I use when working on my car. When I use the front central jack position I can raise the front end high enough to get my jack stands in position under the side lips on both sides of my liftback. This is not the case with the rear. The central rear point is so high off the ground that my jack becomes fully extended before I can get my jack stands under the rear side lips. Right now I just use the two floor jacks on the rear side lips to raise the rear end totally off the ground. The problem with this is that I don't like crawling under my car with just jacks holding it up. I just feel "safer" when I can use jack stands. How do fellow yarisworld members address this problem?
Thanks.....
Randy LeRoy
www.airshowmastering.com
randy@airshowmastering.com
bikegerm is offline   Reply With Quote
Old 02-24-2009, 03:30 PM   #2
I use wood.
Use some small hunks of 2x4 to fill the gap between jack and jack point, or place the jack on some short 2x4 runners.
Old 02-24-2009, 04:47 PM   #3
jkuchta
Drives: 2007 Yaris hatch (red)
I find that the car is stiff enough such that once the front of the car is on stands, you can jack up the entire rear of the car from either side just in front to the rear jacking point (just in front of the rear wheels).
jkuchta is offline   Reply With Quote
Old 02-24-2009, 06:30 PM   #4
texkid
The one with cheese on it
Drives: '10 Corolla S
Not highly recommended, but I put jack at the middle of the rear axle. If you look carefully, you can kinda see the indicator of the midpoint.
texkid is offline   Reply With Quote
Old 02-24-2009, 06:58 PM   #5
cfiimei
Drives: Sedan
DO NOT get under a car that is supported by jacks alone. This has killed many a man.
cfiimei is offline   Reply With Quote
Old 02-24-2009, 07:31 PM   #6
jkuchta
DO NOT JACK THE CAR UP BY THE BEAM AXLE! It will bend, and kill your rear alignment.
If you must use the rear ssuspension to jack up the car, place the floor jack under one of the spring perches. It's a pretty flat place that's designed to take the weight of the car.
Old 02-24-2009, 07:34 PM   #7
texkid
Oooh! Thats a better idea! Thanks
Old 02-25-2009, 01:22 PM   #8
Havana
Havana's Avatar
Drives: 2009 Yaris 3 door M/T
I think the point cfiimei was making was to never get under a car supported only by a jack - not a jackstand. The potential of a jack to roll or accidentally compress is just too dangerous to bet your life on. A solid jackstand should be perfectly safe if properly placed and on level ground.
Havana is offline   Reply With Quote
Old 09-25-2024, 02:55 AM   #9
HDS
Drives: 07 Yaris, Saab 900 Turbo
Is it OK to let the jackstands rest on the beam axle? One on each side?
It's a real PITA to get the rear jacked up high enough. I figure the way to do it is jack it up by the jacking points and put the jackstands on the beam axle.
Or jack it up under the springs and see if that gets it high enough.
HDS is offline   Reply With Quote
2009 - Radio/Aux jack sound issue bobfolgerjr New YARIS Purchase Forum 5 10-24-2011 04:21 PM
