Old 01-15-2009, 11:56 PM   #1
billk
Drives: 2008 Yaris Sedan
Easy Defrost A/c running fix
I seen here in the forums a few discussions about how to stop the A/C from running when in defrost mode. Instead of tearing apart the dash, there is a easier solution.
If you set the vent control halfway between the foot selection and the defrost,on mine it is a little dot, the A/C will not come on. If it is on the defrost selection, the A/C runs. The air will be on your feet,side vents, and front windshield.
Yes I know the A/C helps clear the windshield faster, but when it is 20 degrees outside, the thought of the A/C running to help remove frost is retarded. ( best choice of word)
I posted this in the old unlink the a?c defrost post, but it is buried deep by now.
So if this is a over post, mods do what u want.
b K
billk is offline   Reply With Quote
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 10:17 PM
Gas mileage and A/C Chaad32 General Yaris / Vitz Discussion 18 01-29-2009 05:31 PM
Help Needed: Unlink A/C to Defroster stran DIY / Maintenance / Service 25 01-09-2009 02:50 PM
Save gas by not running A/C with defrost stran Fuel Economy Forum 6 11-20-2008 12:11 PM
Defrost. Racheal DIY / Maintenance / Service 45 01-06-2007 06:52 PM
