Old 07-22-2006, 10:51 AM   #1
Chaad32
Chaad32's Avatar
Drives: 2007 Liftback
Gas mileage and A/C
I was wondering if having your A/C on low actually helps save gas versus having it on hi. I'm no engineer, but doesn't the loss of gas mileage come from the extra strain it takes to drive the A/C pully, and if the A/C is on (no matter how hi or low) the pully is being spun, so doesn't this mean that it doesn't matter?
2007 Liftback
Blazing Blue
Cold Weather, Convenience Package, Arm Rest,
Floor mats, Weathertech vent visors
Chaad32 is offline   Reply With Quote
Old 07-22-2006, 01:48 PM   #2
ECHOKnight2000
Small Car Lover
ECHOKnight2000's Avatar
Drives: A Super Car
You are right to a certain extent, the A/C on eats at gas, period...but if you have it full blast it will eat more at your gas, so you are right at that, if you had it on low it won't eat as much...or what you could do is have it on for awhile till your cool enough and then turn it off until you need it but that might be a nusince. Or you can have the dial at the cool setting and have the air circulation come from the outside with out having the A/C on, of course you are at the mercy of the weather, cause obviously the air coming in is from the outside but I do it often and it can get decently cool even on warmer days, it depends on what your threshold is as far as cool or heat.
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will.
ECHOKnight2000 is offline   Reply With Quote
Old 07-22-2006, 02:57 PM   #3
boxerboy
Drives: WRX ,Tacoma and Yaris
Is the ac on or off? Is the temp control just a mixing valve? I have been running my ac since I got my car, (when I am driving) its been a month friday. I leave it on the coldest setting and run the fan on 2 once it cools the inside.
"PERCEPTION IS SELECTION"
boxerboy is offline   Reply With Quote
Old 07-22-2006, 03:08 PM   #4
Pompeii66
Drives: '08 Yaris Sedan
Had my liftback for 2 weeks now.
Been hot and running the air ever since I took delivery.
Filled up thre times now and have been averaging 32 MPG.
Hoping the mileage increases when it gets cooler and the air is off.
I really would like to see around the 39MPG listed.
Pompeii66 is offline   Reply With Quote
Old 07-22-2006, 04:20 PM   #5
Chaad32
Chaad32's Avatar
OK....so does the tepm setting havbe anything to do with gas consumption?
2007 Liftback
Blazing Blue
Old 07-22-2006, 04:55 PM   #6
twixt
Drives: 07 LB,04&06 ninja 636
Send a message via AIM to twixt
no, as longas the ac is on it is flowing the coolant at the same rate, the temp setting just mixes warm air into the cooler air. also, the low high setting has nothing to do with milage, it just makes the fan push the cold air faster. the pump is going at the same speed no matter what you do
twixt is offline   Reply With Quote
Old 07-22-2006, 05:04 PM   #7
Chaad32
Chaad32's Avatar
That is good to know. My girlfriend always makes me keep the A/C on low because she doesn't want to burn up gas. HAHA I win.....
2007 Liftback
Blazing Blue
Old 07-22-2006, 05:06 PM   #8
Chaad32
Chaad32's Avatar
Although, doesn't the A/C pump turn on and off periodically depending on how hi the fan is going? Or is what you are saying is that no mater how hard the fan is blowing the A/C is always kept at the same temp in the coils and thus the same gas is being used.
2007 Liftback
Blazing Blue
Old 07-22-2006, 06:06 PM   #9
ECHOKnight2000
Small Car Lover
Drives: A Super Car
Opps! My bad
Like Chaad32 mentioned when I don't have my music up loud I can hear the A/C pump go off and on, I can hear a different tone in the sound, like its working then it shuts off I don't have my a/c on, its just the cool setting with the circulation coming from outside, unless I'm hearing something else...I'm not stating a problem just an observation.
Old 07-22-2006, 06:21 PM   #10
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
I keep it as high as I need it to be comfortable. I wont pinch penny's to make my commute any less uncomfortable then it has too.
Old 07-22-2006, 06:36 PM   #11
Dylanby
Drives: RS 5-DR
Ditto.
Dylanby is offline   Reply With Quote
Old 07-22-2006, 08:24 PM   #12
Chaad32
Chaad32's Avatar
I have actually noticed in other cars that I have owned that when on the interstate and with the A/C on and the windows rolled up I get better gas mileage that with the windows down......
2007 Liftback
Blazing Blue
Old 07-22-2006, 08:40 PM   #13
boxerboy
more aero dynamic with windows up
Old 07-22-2006, 08:44 PM   #14
Chaad32
Chaad32's Avatar
That is what I thought to....but I didn't realize how much aerodynamics plaied into the equasion.
2007 Liftback
Blazing Blue
Old 01-28-2009, 02:30 PM   #15
LittleRed
LittleRed
Drives: 2008 Yaris Hatchback 5spd
You can save gas by..cooling the car...turning off the a/c and putting it on recirc..thus recirculating the already cool air on low 1 or 2 setting it will stay cooler longer..i assume..until it gets warmer...then turn it back on...but may be wrong...makes no since to turn the a/c off and use the fresh air setting , thus bringing the warmer air in...using the a/c at highway speeds..has a pretty minute effect on milage..since the car gets close to 40 mpg...why not be comfortable...thats why they invented a/c..people are too obsessed with gas mileage..cant we just enjoy the car..i do....it already saves gas by not having a power steering pump...
LittleRed is offline   Reply With Quote
Old 01-28-2009, 04:26 PM   #16
NJBob
NJBob's Avatar
Drives: 2008 Yaris Liftback
You only lose 2-3 mpg by using the air. At speed you still lose with the windows open. May as well use the A/C. Remember if your car has been sitting all day in the heat, all those surfaces (upholstery, dash, steering wheel) are kicking out heat big-time so it'll take longer to cool down.
Old 01-28-2009, 04:39 PM   #17
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
Sharp as tacks guys...... answering a post from JULY 2006 !!!!
Old 01-29-2009, 04:31 PM   #18
NJBob
NJBob's Avatar
Some people, like me, won't go back 3 years hunting for a post. A lot of noobs just want answers and ain't that why we're all here....to help each other? Right on!!
Noise in the A/C System cburac DIY / Maintenance / Service 1 05-16-2006 06:14 AM
