![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
Polishing Throttle Body
T.B polishing is really popular here, $50 for full polishing inside the T.B..i do not know about the hp gain but i want to know if anyone tried this 😃😃😃😃
![]() Sent from my SM-J700F using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
Mr. 155 and climbing
There would be no power gains really. The only possible benefit that I could fathom is maybe slightly quicker butterfly actuation.
Sent from m-o-b-i-l-e
2010EGGHATCH
Drives: White 2010 Yaris Hatch Join Date: Apr 2016
I just picked up a 1zz throttle body for my Yaris. That's the only real throttle body gain I've heard of for these cars so far.
Sent from my SM-G920T using Tapatalk
IG: 2010EGGHATCH |
![]() ![]() ![]() Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR Join Date: Mar 2007
From what I was reading up on, there can be some benefits to polishing the throttlebody, but usually when porting it a bit also. It had to do with removing any imperfections and opening the entrance a bit. Mostly trying to just remove the step as the air enters the TB.
That being said, even doing that on a factory setup probably won't net any benefit, with an intake and exhaust possibly, with an all out build I would imagine that it would help squeeze any hidden potential out of it.
Project so far: 2zrfe swap, Megan racing coilovers, TRD rear sway bar, whiteline bushings, RPM long tube header, midpipe, and DC sports xD exhaust, brake upgrade in front, MI stainless braided lines all around, matte paintjob, Takada cold air intake, various gauges, rear seat and belts removed. Future: Turbo. |
#5 | |
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
Then you did something wrong because low end is greatly improved with the 1ZZ TB.
#7 | |
![]() Drives: '15 Yaris 3 door Join Date: May 2016
Does anyone know is a 1ZZ swap will work for a 3rd gen Yaris? (2015 3 door)
| Polishing 1NZ Throttle Body | rabbito | Performance Modifications | 3 | 02-25-2016 12:36 PM |
| Throttle Body Swap | Ryze268 | Performance Modifications | 12 | 04-27-2014 02:46 PM |
| Cleaning throttle body | ToTo | Performance Modifications | 18 | 07-27-2011 06:20 PM |
| For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers | m911gt | Items for Sale by private party | 6 | 04-25-2009 09:52 PM |
| Toyota Throttle Body Spacer: the Best Fuel-Saving Device | davidmills | Performance Modifications | 1 | 07-02-2007 12:38 AM |
