Old 05-22-2016, 11:31 PM   #4
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
Originally Posted by NJP440 View Post
I just picked up a 1zz throttle body for my Yaris. That's the only real throttle body gain I've heard of for these cars so far.
Sent from my SM-G920T using Tapatalk
yeah but 1zz TB must use intake kit...theres like no point if you dont use intake...im not trying to use intake kit(which i did before and lost low end)...
Sent from my SM-J700F using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
Polishing 1NZ Throttle Body rabbito Performance Modifications 3 02-25-2016 11:36 AM
Throttle Body Swap Ryze268 Performance Modifications 12 04-27-2014 01:46 PM
Cleaning throttle body ToTo Performance Modifications 18 07-27-2011 05:20 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
