![]() ![]() Drives: MY HB Join Date: Oct 2008
Alignment help :(
Just got my alignment dot at a local shop
I got coilover and camber bolts installed. So i drop the car off to get it aligned and i get a call from the shop saying my toe is fine but my camber is off and not "correctable" front left side front right -1.8 -3.5! can someone explain?? he said he was unable to adjust anything and charged me $50 for his time this is the kit i got on the car now http://shop.microimageonline.com/pro...4&productId=72 |
Did you tell the mechanic you bought ADJUSTABLE camber bolts?
Also, -3.5 is farther than the bolts list they go on the microimage site. 15mm Adjustable Camber Bolts +/- 1.75 degrees. Did you hit a curb or something? You might have broken a bolt? |
i did he said to contact the manufacture and i did not hit anything he blamed it on my coilovers
#4 | |
What kind of alignment machine is he using the kind where you still have the comp the heads or the laser kind. Maybe the guys a idiot and dosnt have the adaptors installed on your wheels correctly.
Sounds that way , or the guy doesn't know what he is doing ,
ie camber bolts required to correct problem .
What?
Explanation: You need to take your car to a more performance-oriented alignment shop.
Better yet, just do your own alignment. There's nothing to adjust in the rear, and only two simple adjustments to make in the front. Invest in a cheap construction level to check camber. Roughly 1 degree of camber for each 1/4" the top of the wheel is in more than the bottom of the wheel... you can do some trig if you want to be more accurate, but what's most important is that you're even from left-to-right. Within 1/4 degree is plenty close enough. Check toe with a tape measure. Getting zero toe is easy, measure from tread-groove to tread-groove on the front side of the tire and the back side of the tire. If the measurement is the same, you're at zero. Ideally, you'll want maybe 1/16-1/8" of toe-in. All you need is a level driveway or garage, some common hand tools, and a little patience. Oh, and if you have a proper coilover kit, you shouldn't need camber bolts. The lower hub mounting bolt hole should be slotted for adjustment. |
#10 | |
What?
Caster is non-adjustable on the Yaris, so you can't credit your alignment tech for that. It is what it is.
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
I don't get what happened with this outcome...you bought another set of coilovers?
MicroImageonline forums - Shroomster Xda Forums - Shroomster Androidforums - Shroomster I'm noticing a pattern...... |
sooo you got the idiot who told you he couldn't align the car in the first place to align it anyways?
no he told me that after he "did the job and dedicated his time"
well the car is driving straight and you now have a better handling yaris...so hey
What?
Um... you didn't really ask "what you can do", you asked for an "explanation". The explanation is that your alignment tech is afraid of aftermarket parts. Doesn't understand them, doesn't want to.
As I said last night, find a shop that is more performance oriented or just do it yourself. Take the wheel off, loosen the two strut-to-hub mounting bolts and see what you can do with it. Check your strut assembly and see if it has slotted holes like it should. If it does, I'd put stock bolts back in rather than the (thinner and weaker) camber bolts. Unless something is bent, you should be able to get both sides to the same amount of camber. |
| How soon to get alignment after TRD spring install? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 03-24-2009 09:08 AM |
| Dealership explains no need for alignment | jmjonesey | DIY / Maintenance / Service | 6 | 04-23-2007 05:20 PM |
| Suspension alignment after new springs? | mrrock | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 02-14-2007 02:05 PM |
| Wheel Alignment Data | Asif Kazani | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 01-22-2007 01:48 AM |
| Front End Alignment after Spring Install? | OK Yaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 08-26-2006 08:46 PM |
