Old 04-13-2007, 10:04 AM   #1
jmjonesey
jmjonesey's Avatar
Drives: Red 2007 Yaris Sedan
Send a message via AIM to jmjonesey
Dealership explains no need for alignment
I bought my Yaris brand spanking new with 18 miles on it, and after i got it on the highway, i noticed that it pulls ever slightly to the left. I figured hey, whatever, and before I even hit the 800 mile mark, I took it in for an alignment as per Toyota's warranty (which says any alignments need to be done before 1200). The odd thing about it thought, and they even gave me the alignment paper showing that it is off by no more than .02 degrees thrust angle (which is practically dead on) that the reason it pulls to the left is because being a smaller car it does not have positraction and the transaxle just does this. I figure they cant be lying to me because I walked around back of the service station and even saw them performing the alignment.
Is anyone else experiencing this phenomenon? What do you guys think?
jmjonesey is offline   Reply With Quote
Old 04-13-2007, 10:18 AM   #2
St_G
Drives: Black 2007 Yaris Liftback 1.5
Haven't seen that, sorry. My car actually pulled hard to the right brand new and while the guys at the dealership said it was "very unusual" for one of Toyota's cars to need an allignment straight from the factory like that, when they looked at it, it was indeed significantly off. They straightened it and I haven't had any troubles with it since, either to the left or the right.
St_G is offline   Reply With Quote
Old 04-13-2007, 10:58 AM   #3
Black Yaris
der Zeck
Black Yaris's Avatar
check your tire pressure... is those are dead on, then ask them rotate your tires from side to side, if your car then pulls the other way, one or more of your tires has what is called a radial pull (one tire was wound tighter than another). Basicly the next step is they will warranty out 1 or 2 of your tires and that should corrct the problem
Old 04-13-2007, 11:25 AM   #4
jmjonesey
jmjonesey's Avatar
omfg why didnt i think of that thanks black yaris, ill report back after i get a chance to check the pressure. Makes sense now (I summon forth the Homer D'OH)
Old 04-13-2007, 11:26 AM   #5
Black Yaris
der Zeck
I was an alignment tech many many years ago, it was the first thing I used to check
Old 04-19-2007, 02:22 PM   #6
Yarisguy13
My car did that too!!!!!!!!!!
The Toyota tech did the alignment and it still pulled to the left. He checked it out again and found out that you need to rotate the tires. After the rotation the car drove great. Hope this helps.
Yarisguy13 is offline   Reply With Quote
Old 04-23-2007, 04:20 PM   #7
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
I have the strange feeling that my car does that too, sometimes.
Edmonton dealership review Vervepipes Canada 0 03-18-2007 08:02 PM
Dealership wants $64.99 for Oil Change? ScottFern DIY / Maintenance / Service 15 09-21-2006 10:49 AM
