In between cities
Drives: 2006 yaris ce Join Date: Feb 2006
looking for 2007 vitz part number
I have the rear disc axle on my 2006 yaris, now the rubber boot is damaged and the lower slider pin is also giving problems, I don't think it was the correct slider pin when I first got the axle. I added grease but the pin has chips like it was stuck before and was forced out with wrench or screw driver.
Anyways does anyone have or could get the toyota part number for those items? Also is there another toyota in canada or usa that uses the same parts instead of ordering from Japan. Thanks. |
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
Have you tried parts from a 2015/2016 hatchback SE? I know they come with rear disk brake axles, so you might have some luck in finding them in Canada, rather than having them shipped from Japan?
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
In between cities
I'll try a 2016 yaris for the rubber boot, I know the top pins aren't the same. There the same as the corolla xrs, but the bottom isn't the same.
i have the same issue as you regarding the slider pin fro the caliper! My pins fit just fine, and i shaved a little bit off to make it work..but i ordered pins for a 09 corolla xrs rear caliper since they also share the same brake pad, and same sized disc. Sorry, it's still sitting in a bag. I need to get rear discs for a '12+ yaris SE to replace first, to go along with my TOM's pads.
| Help finding part number | joell | DIY / Maintenance / Service | 19 | 01-06-2015 02:41 PM |
| 2010 Vitz RS Modellista Completed Car | Vitz Rs Modellista | Photo-Video-Media Gallery | 38 | 11-18-2014 12:25 PM |
| NGK spark plug part number?? | Jerkratt | Forced Induction Forum | 16 | 03-27-2012 07:06 PM |
| Does anyone know the part number for OEM rally style spoiler? | caineroad | General Yaris / Vitz Discussion | 1 | 08-19-2009 12:31 AM |
| So there is no part number for the LED tail light? | caineroad | General Yaris / Vitz Discussion | 3 | 08-17-2009 08:09 PM |
